RV.Net Open Roads Forum: When do you decide to level left to right??
 > When do you decide to level left to right??
Page of 5
2oldman
Soap Lake WA
Posted: 04/10/12 01:23pm Link  |  Print  |  Notify Moderator
greende wrote:
This is a very neat app.
Welcome. I had to adjust mine using a bubble level since my Droid Razr doesn't have a flat back.
Michelle.S
Eastern Coast of Florida
Posted: 04/10/12 03:11pm Link  |  Print  |  Notify Moderator
OK, I'll be the smart A.. here. Park, unhook, pull TV forward out of the way, Hit the Auto Level button and presto jacks come down and it levels it's self. No blocks, no fuss, just the initial cost to have the system installed.
2011 Chevy 3500HD Extended Cab DRW, Dmax/Allison, 2012 Redwood RW36RL, Dual ACs, Fireplace, Sleep Number Bed, Auto Sat Dish, Combo Washer/Dryer, Auto Level Sys, Disc Brakes, Onan 5.5K Gen, 17.5" "H" tires, Dual Awnings, Full Body Paint, Tri-Glide Pin Box
Nana of 11
Sandpoint Idaho
Posted: 04/10/12 04:00pm Link  |  Print  |  Notify Moderator
OK Smarty pants... what set up do you have installed and is it available in an after market application?
notruffinit
Minnesota
Posted: 04/10/12 08:21pm Link  |  Print  |  Notify Moderator
Wills250psd wrote:
It is the first thing I do. I pull on the sight look at my level and use the proper amount of blocks to level up then unhook and level front to back.
X2. But we loved the Lynx Levelers to do the job. We call them our LEGO blocks. Still have 2 sets even though we have the BIGFOOT
'11 Ram 3500 Cummins
'12 Cameo 34SB3
djgarcia
Northern, Ca. , USA
Posted: 04/10/12 11:48pm Link  |  Print  |  Notify Moderator
I like the bubble level that is attached to the front of the pin box. Mine measures both side to side and front to back. The Left to right level is important because of the refrigatior.
Dick
djgarcia3@att.net
laknox
Arizona
Posted: 04/11/12 01:27pm Link  |  Print  |  Notify Moderator
HTT to be? wrote:
R to L is the first thing to be corrected. While we are still hooked up we check the level to see if we need to lay a block or two down to have her sitting level. So we back her in to the exact spot we want the trailer, then ck for r/l level, if needed, pull forward just enough to lay blocks needed, then back her up and ck she is right. Then we put in chocks and unhook
X2...all the way down the line. :-) Amazing how little out of whack you can notice, and be annoyed by. :-)
Lyle
1936 John Deere Model A
3 dog nights
Central, Virginia USA
Posted: 04/11/12 02:27pm Link  |  Print  |  Notify Moderator
I don't level the camper, I level the refer! Put the bubble level in the freezer unit while still connected. level the refer and you can live with the trailer.
bpounds
Whittier CA
Posted: 04/11/12 02:44pm Link  |  Print  |  Notify Moderator
My parents always did that on their old trailers. Apparently being level was fairly critical back then. They are not critical now, so there is no reason to do that, but I know old habits die hard. If it works for ya, great.
I've known others who leveled with water in a cast iron skillet on the range.
2006 F250 Diesel
2011 Keystone Cougar 278RKSWE Fiver
Mile High
Denver, CO
Posted: 04/11/12 02:48pm Link  |  Print  |  Notify Moderator
Once I get nausiated because the trailer is listing to one side or the other, I don't care if the beer is cold anymore
2006 Ford F350 4X4 SB CC SRW Powerstroke 6.0
2013 Redwood 36RL - full paint - disk brakes
"Comparison is the thief of joy! - Theodore Roosevelt"
DodgeVoltage
Nanjemoy, MD
Posted: 04/11/12 03:23pm Link  |  Print  |  Notify Moderator
I do the same, but have found that if the site is too unlevel side to side, I still have to use blocks under the wheels. The autolevel system torques the frame just enough to get it level that my garage side door won't close correctly. It binds and the dead bolt won't lock. It also lifts the wheels off the ground. I don't like it torquing it for long periods of time.
2010 Dodge 3500 Mega Cab Cummins Diesel DRW
2009 GMC 2500HD D/A Crew Cab
2012 Dutchmen 3795 Voltage Epic Package
2012 Smart Passion for Two
2003 Suzuki Intruder 1500LC Cruiser
AD USAF 1996-2011 1700+ hrs E-3B/C AWACS
NYANG 2011-Present
K-State Wildcats!
Page of 5
