RV.Net Open Roads Forum: Anyone change their bulbs out to LED?
 > Anyone change their bulbs out to LED?
Jayco254
Eastern Missouri
Posted: 04/10/12 11:29am Link  |  Print  |  Notify Moderator
I won't be changing mine. I guess I'm the only person that don't like them, don't like the looks when their on. Can't really say why but I just don't like the looks of them.
Tom, Kathy, Nikki, & Kelly
Pets: Lady - Texas Heeler, Dinger - Rhodesian Riidgeback Mix
2008 Ford Expedition Eddie Bauer 4x4 5.4 ci 3.73 gears
2008 Dodge Ram SLT Big Horn 4x4 5.7L Hemi 3.92 gears
2007 Jayco Jayfeather EXP 254
Husky W/D, P-3
zztinker
Central California
Posted: 04/10/12 12:18pm Link  |  Print  |  Notify Moderator
You probably don't like the blue color of the led light, these led's are a warm light and are very simular to your standard lights...(.1x BA15S 1156 1141 Dome bulb 36-1210 SMD LED,Warm White)
These led's are brighter than your standard bulbs and use way less energy. I changed all the inside bulbs. They come direct from China on Ebay....about $4.00....
2010 Jayco Eagle Super Lite 31.5RLDS Fifth Wheel, 2006 Ford 350 PSD SRW, long Bed, Champion 2000i inverter Generator and a Champion 3500/4000 Gen.
EricGT
PA
Posted: 04/10/12 12:32pm Link  |  Print  |  Notify Moderator
beemerphile1 wrote:
For tail lights and brake lights stay away from the LED lamps. Either replace the fixture completely or at least use the retrofit flat panels. The ones that are similar to the incandescent lamp will only have a dim glow in the center of the fixture.
Do NOT get these;
Do NOT get these;
Uh oh, those are the types I was looking at.
So, they are no brighter than incandescent bulbs?
2002 'The Rogue' by Mckenzie div of Monaco Coach
24' E450 chassis, V10, Class C, Single slide
Suzanne and Brad
Oregon
Posted: 04/11/12 07:20am Link  |  Print  |  Notify Moderator
We did and are very happy with the results. Due to cost, we chose not to do all the bulb,s but the main ones in the living area - definitely noticed it brighter (whiter) and less heat.
Happy Travels!
Suzanne & Brad
tenbear
Northern Vermont, USA
Posted: 04/10/12 03:51pm Link  |  Print  |  Notify Moderator
The brightest SMD (surface mount diode) LED lights will use the 5050 SMD LED. It is like 3 diodes in one package. You will also need many of them to have a bright light. You probably also want the bright white, rather than the warm white, for external lights. Buy one and see if you like it. The Chinese LEDs on eBay usually have free shipping.
Class C, 2004/5 Four Winds Dutchman Express 28A, Chevy chassis
2010 Subaru Impreza Sedan
Camped in 45 states, 7 Provinces and 1 Territory
tenbear
Posted: 04/10/12 04:01pm Link  |  Print  |  Notify Moderator
I forgot to add a link. Have a look at this seller. He seems to specialize in automotive.
EASY.RIDER
Mo
Posted: 04/15/12 05:33pm Link  |  Print  |  Notify Moderator
I must be in the minority, am not a big fan of led's, they are brighter, use less power, and that's the reason I bought them. However mine have not lasted very long, and also should add they were a lot more costly than regular bulbs.
Jayco254
Eastern Missouri
Posted: 04/11/12 09:19am Link  |  Print  |  Notify Moderator
zztinker, I guess you're right I have a couple of led flashlights and it's the blueish look that I don't care for, the same with the blueish headlights on some of the newer cars. But when I'm behind a vehicle with led brake lights they bother my eyes, but my eyes are real sensitive anyway. Since I don't dry camp I'm not worried about energy usage so I'll just stay with my regular bulbs, thanks anyway for telling me about the more normal looking led's.
