RV.Net Open Roads Forum: Class A Motorhomes: Replacement Icemaker/Repair Floor Slide
 > Replacement Icemaker/Repair Floor Slide
Don Parrish
AZ
Posted: 04/10/12 07:59am Link  |  Print  |  Notify Moderator
Could someone please give me the model number for the direct replacement icemaker for a Norcold 1200 which can be purchased at Lowe's (?)or somewhere like that. I recall it's under $200.
And then...the floor slide at the entry door is inop (05 Diplomat)...at least it's in the stowed postion. Have checked fuses, circuit breakers and wiring. Have yet to actually check the operating switch, but I'm not lucky enough for it to be only that. Where and how is the access to the operating mechanism. So far it seems this was hung in space and the coach was built around it like so much of these wonderful machines.
Thanks for any help. Don
The Texan
Meridian, Idaho
Posted: 04/10/12 08:41am Link  |  Print  |  Notify Moderator
Don,
I don't know what is wrong with your icemaker, but have you seen this service bulletin ?
The number you are looking for is/was Whirlpool Mod. ECKMF94, Lowe's #57773
Also available at Amazon, Direct Link
Bob & Betsy(FishNFanatic) - USN Aviation Ret'd '78 & LEO Ret'd '03 & "Oath Keeper Forever"
'05 HR Endeavor 40PRQ, 400 Cummins-Pulling our '11 Silverado LT, Ex Cab 6.2L NHT 4x4, w/2010 Rzr or 01 V Star in back.
Where the wheels are stopped today
Valkyriebush
Yuma/Port Townsend
Posted: 04/10/12 08:55am Link  |  Print  |  Notify Moderator
@ Texan. That model # is that standard for the 1200 LRM regardless of year? Mine has a weird leak that causes a big chunk build up in the bin. Will that model work in my unit, being an 03?
Command Master Chief (AW) USN, (ret)
2003 Fleetwood Excursion 330 Turbo Cat 39D
2000 Jeep GC
2005 Big Ruckus (Rides Behind Jeep)
2003 VTX 1800
The Texan
Meridian, Idaho
Posted: 04/10/12 09:00am Link  |  Print  |  Notify Moderator
Supposedly, it is the only one they have used, since they started building the 12xx in 1996 or so. So I will go out on a limb and say yes, it will fit yours also.
MCDDY
Louisiana
Posted: 04/10/12 04:07pm Link  |  Print  |  Notify Moderator
Don
Much less than $200, +- $50 @ Lowes. Easy change out with 4 bolts and explicit instructions.
As far as the step cover, check out the distribution valve in the genny compartment. It will be attached to the firewall above the genny. I air line inlet and 2 outlets. That's what makes it work but when the cover is extended look under it and there is an air cylinder that actuates to extend or retract it.
Been there doen that.
Dave
GEAUX TIGERS
Dave, Miss Sue & Lucy the Scotty
Big Easy Area.
FMCA 153192
2000 Monaco Windsor, 40' 2 Slide, ISC 350 HP.
2012 Honda Pilot or 1998 Blazer Toads
Aventa 2, Brake Buddy
Don Parrish
AZ
Posted: 04/10/12 04:48pm Link  |  Print  |  Notify Moderator
That should do it. Thanks to all. Don
Valkyriebush
Yuma/Port Townsend
Posted: 05/08/12 08:08am Link  |  Print  |  Notify Moderator
@ Texan. Thanks for the tip and Lowes part #. Changed mine out and TWO friends as well. What a easy job. Sure beat the price CW gave me to do it, and no more ice mound build up. Price $99.00
