RV.Net Open Roads Forum: Towing: Buying a used pullrite hitch, maybe...
Search only in Towing
Open Roads Forum  >  Towing
 > Buying a used pullrite hitch, maybe...
porkchop1221
US
Posted: 04/10/12 10:56am Link  |  Print  |  Notify Moderator
A few people are offering to sell their pullrite auto slider. I'm always a little leary about buying used. So I'm wondering what people thoughts are on buying a used hitch?
What questions should I ask? How old is the hitch? How long have you had it? How long have you used it?
What's a decent price for used hitches?
What else should I be asking or looking for?
If you'd like to pm me your answers I would appreciate that as well.
Thanks!
2012 GMC 3500HD, Diesel, Crew Cab Standard Bed, SRW
2013 Cyclone 3010 (to be picked up)
five'er
Canada
Posted: 04/10/12 11:05am Link  |  Print  |  Notify Moderator
I sold mine after I sold the Fifth wheel for around a thousand or so dolalrs (A real good deal I think).
My only advice is.. Make sure the rails are in good condition and make sure you can find a place that will install a used hitch. You might be suprised to learn some places wont. You may need to tell a story about how it's a new truck but transfered hitch..
n7bsn
Yes
Posted: 04/10/12 11:26am Link  |  Print  |  Notify Moderator
Mine us used, came with the truck (part of why I was interested), it's a good hitch (Superglide). But it was in great shape.
2008 F350SD V10 with an 2012 Arctic Fox 29-5E
When someone tells you to buy the same rig they own, listen, they might be right. When they tell you to buy a different rig then they own, really pay attention, they probably know something you don't.
Jim Cindy
Northcentral, PA
Posted: 04/10/12 11:08am Link  |  Print  |  Notify Moderator
Brother in law just bought one for 1,000. I have one and your biggest thing to look at are the rails the hitch plate slides on when you turn.
Few scratches and no gouges in the rails are what to look for. Does the hitch have visible lube or SlipPlate coating on the rails. The rails can be unbolted and turned over if necessary.
Great hitches, have had mine for amost 6 years
PBH Portable Beach House
2008 GMC 2500HD Duramax Allison
2009 Cameo 34CK3
MorRyde IS, Disc Brakes, G614's
PullRite Super Glide Hitch
Propane fueled Yamaha EF 2400is
kaydeejay
SE Michigan, USA
Posted: 04/10/12 12:22pm Link  |  Print  |  Notify Moderator
X2 on the smooth sliding surfaces.
Gouged surfaces would suggest a lack of lube.
Keith J.
1999 Sunnybrook 27RKFS Fiver.
2005 GMC Sierra 2500HD CC/SB/DA 2WD, LBZ air cleaner, 52 gal Titan tank, Bilsteins, Line-X, Westin steps, Prodigy, Retrax cover, 16K Superglide, 5th-Airborne pin-box, Multi-vex mirrors, TST TPMS.
mapguy
Puget Sound
Posted: 04/10/12 05:52pm Link  |  Print  |  Notify Moderator
This is important but two other areas of inspection too.
Check the pin latch release lever is not bent(it is what trips the pin latch as you back in).
Check the bearing/roller C3 on the turntable. Earlier models used a sealed roller bearing that can fail. Later models are a sleeve bearing.
Update the bearing immediately if the early style doesn't freely spin without a gritty feeling.
4100/4400 breakdown here
http://www.pullrite.com/pdfs/4100_4400_SG_OM.pdf
phillyg
Front Royal, VA
Posted: 04/10/12 06:10pm Link  |  Print  |  Notify Moderator
Bought my used 12k SG from a fellow advertising on CL for $700. He had upgraded his truck and FW and he needed a different hitch. It came with the mounting brackets for his old truck (Chevy) that of course would not fit my truck, so I had to buy the bracket kit. All in all a very good deal and much less than new. It was/is in great shape with no galling on the rails.
2002 Keystone Cougar 286, 8,400lbs loaded, pulled with a 2004 F150 Supercrew, 5.4, 3.73 gears. Retired and enjoying life
porkchop1221
US
Posted: 04/11/12 06:10am Link  |  Print  |  Notify Moderator
Thanks everyone!
I'm getting pictures emailed to me with the story behind them. I can't physically see them until they get shipped. They are pretty far away. I'm assuming shipping will be pretty outrageous as well.
Would anyone mind if I send them the pictures so they can tell me what they think? Private message me your email address and I will send you the pictures.
Thank you all for helping me out!
n7bsn
Yes
Posted: 04/11/12 10:16am Link  |  Print  |  Notify Moderator
I don't think I would buy a used hitch sight-unseen, ever
porkchop1221
US
Posted: 04/13/12 06:03am Link  |  Print  |  Notify Moderator
So after looking at the pictures and hearing the stories of the used hitches I've decided that it doesn't make sense to buy the used hitches. They both wanted 1k for the whole kit and kaboodle and one of them he bought used many years ago. And the other person had a failure and rebuilt the 16k into an 18k. So both do NOT have any sort of warranty.
I went online and at Tweetys, I can buy the 18k superglide, industry standard rails and capture plate for around 1500 shipped and no tax.
The people selling the used hitches wanted 1k for them and I don't think that would include shipping which would probably cost and arm and a leg. For 500 more, I'd get new everything and a warranty.
I'm hopefully going to have it installed with a friend. Either way, I'd have to get it installed.
Thank you all for your advice. I appreciate it!
Either way, the
