RV.Net Open Roads Forum: Outfitter - where is the electric jack control board?
 > Outfitter - where is the electric jack control board?
joerg68
Ueberherrn, Germany
Posted: 04/10/12 11:34am Link  |  Print  |  Notify Moderator
Hi there,
does anyone here know where I can find the receiver/control board for the electric jacks (Happijac) in an Apex 8 LB?
The left rear electric jack on our Outfitter quit working. Everything else works fine. I suppose it is a fuse or a wire that came off.
Thanks and Best Regards,
Joerg
"Pickups are very handy cars. One step on the brakes, and everything you need is right behind you!"
terryrey
Utah
Posted: 04/10/12 02:41pm Link  |  Print  |  Notify Moderator
Perhaps an email to Bob Ward at Outfitter would get you the answer to the location of the control board and also some suggestions on what could be causing your left rear jack to not work. On my Apex 8, the controllers is mounted inside the left rear generator storage compartment. Terry
Geewizard
Alaska, USA
Posted: 04/10/12 05:04pm Link  |  Print  |  Notify Moderator
Mine is inside the area where you access the battery box...under the dinette....along with the water pump, etc.
Outfitter Apex 8
Toyota Tundra Double Cab
Mt Robson, Canada
Hodag1
Mount Wolf, PA
Posted: 04/10/12 05:12pm Link  |  Print  |  Notify Moderator
My controller is in the generator compartment on my Apex9.5.
It should not be here where it can be banged by the generator. Under the dinette seems better.
* This post was edited 04/10/12 05:25pm by Hodag1 *
Hodag1
Mount Wolf, PA
Posted: 04/10/12 02:50pm Link  |  Print  |  Notify Moderator
It had been suggested to leave the motor engaged and manually
jog the jack back and forth to unstick it.
I had a bad motor within 6 months of new and Happijac sent me a new one and paid for return shipping.
Steve_in_29
29 Palms (SEMPER FI), CA 92277
Posted: 04/10/12 04:24pm Link  |  Print  |  Notify Moderator
The controllers have been located in at least two places that I know of. One is inside the dinette by the converter and the other is on the back wall of the generator storage compartment.
Another place to look for a loose wire (a two prong connector actually) is underneath the small plastic cover where the jack wires go through the camper's wall
2007 F350,SC,LB,4x4,6.0/Auto,35" tires,16.5 Warn,Buckstop bumpers
2007 Outfitter Apex9.5,270W solar,SolarBoost2000e,2 H2K's,2KW inverter,2 20lb LP on slide out tray,4 Lifeline AGM bats,Tundra fridge
95 Bounder 28' ClassA sold
91 Jamboree 21' ClassC sold
joerg68
Ueberherrn, Germany
Posted: 04/11/12 01:14pm Link  |  Print  |  Notify Moderator
Found it, blown 20A fuse. The jack works fine again. Receiver is under dinette next to water pump. It was a one minute fix :-)
Thanks a lot to all who helped,
Joerg
joerg68
Ueberherrn, Germany
Posted: 04/11/12 12:58am Link  |  Print  |  Notify Moderator
Thanks a lot for the suggestions! It is raining today so I won't go out to hunt for the module. I have sent a request to Outfitter as well.
It is definitely not in the generator compartment. I will see if I find it under the seat.
The jack is unstuck. It just didn't work anymore after a 3 hour drive. We found out when we wanted to raise the camper a bit to correct the position. It had shifted a bit and in doing so turned sidewise so that one of the fastguns got very close to the bed sheetmetal.
I'll keep you all posted how it turned out.
Thanks a lot,
Joerg
dadwolf2
Henderson,NV
Posted: 04/10/12 09:00pm Link  |  Print  |  Notify Moderator
Mine is in the outside storage compartment, left rear side. Underneath the cover (that is hard to get off) is where the fuses for each jack are. Don't ask me how I know!!
2005 Dodge Ram 2500 CTD,4X4,NV5600,Pullrite superglide
2005 Skyline Rampage 289
2011 Outfitter Apex 8 (Love it)
