DrHitch
Naperville IL
With all the subsystems going on in my motorhome, I'm wondering what is giving other owners their biggest headaches. Some examples:
Generator operation and maintenance
Leveling system
Satellite receiver
Lighting system
Security system
Slide-out motor system
What other things are problematic with your motorhome? Is there any way to manage all these components? I'd really like to get some input on this topic.
Thx
Doug
djevans
Tennessee
DrHitch . . .
Are you looking for "proactive "electrical" maintenance" schedule" or what exactly are you trying to avoid. A lot of us haven't had any issue(s) with what you listed. (at least I haven't the slightest issue "electrically")
I do have a small roof water leak that I haven't located yet, and the chassis A/C compressor seized once requiring replacement. Let's see, what else...I had a gasket on the exhaust brake burn through, leak, and start "whistling." (R & R gaskets) Oh, and had to have the computer firmware updated at CUMMINS (under warranty though)
Aside from those, I really haven't had any real nasty problems, but nothing really electrical either. I do have to water the batteries frequently. (every couple of months or so - that is easily my most irritating "electrical maintenance item" - hard to access some cells)
Don . . . near 36.171N 086.784W, TN near here
WA4ZFN
2003 Fleetwood Revolution 40C - HONDA Element
350hp Cummins ISC
2006 GL1800 HONDA GoldWing
- - - P i c t u r e s - - -
"HOPE" is not a strategy . . .
katoomer
Vancouver
The biggest source of trouble with our coach is the hot water heat. It has one small part that always fails.
The other problem we have is our Atwood levellegs. Ihave to reset them again.
2009 Newmar Ventana 3942
2010 Pace Shadow 18ft
2010 KTM 450 XCW six days
2010 Can Am Outlander 650 XT
2009 Yamaha TTR125
1989 Douglas Skater 21' Twin 2.5s
xctraveler
Livingston TX
In 8 years of ownership and 99,000 miles we have had two electrical failures.
1. Generator would not run, phase controller got its nose out of joint. Quick fix seem to remember $150 tech charge. Happened in 7th year of ownership, nothing to be done to prevent - stuff happens.
2. This past winter, Bedroom Slideout motor quit with bedroom extended, when else? had road service (coach-net) retract room and book appointment for repair. Lesson learned - learn how to retract slideout room manually and where motor is and how to change it out before you wake up in WalMart parking lot in Fort Stockton TX needing to get underway.
Batteries are batteries, they want attention once a month to assure water levels. Uless they are AGM. That's it in this coach.
Paul
Trucking down the road in our new Phaeton 36QSH on Freightliner Chassis with a Cummins 380 pushing it. 2011 Cherry Red Jeep Wrangler Rubicon with US Gear Unified Tow Brake System. Check out my blog
FMCA 352081 SKP# 99526
LVJ58
Las Vegas, Nevada
Other than replacing the isolator solenoid and cooling fans on back of refrigerator a couple of times, and 1 burnt wire in the ATS, no major problems with electrical system in our 12years of ownership.
Jim & Sherry Seward
Las Vegas, NV
2000 Residency 3790 V-10 w/tags & Banks System
2003 Suzuki XL/7 toad
garry1p
Oklahoma
Stuff happens;
You really can't plan on any particular type of failure what fails on some rigs may never fail on others.
I don't think I have ever had the same failure twice.
Garry1p
1990 Holiday Rambler Aluma Lite XL
454 on P-30 Chassis
1999 Jeep Cherokee sport
Admiral
Upstate Ohio
The Intellitec battery control center. First the board went then the isolator solenoid. Now it's not charging the coach batteries again...Oy.
2004 Damon Daybreak 2960F V-10
05 Honda Element LX
Compassion should be voluntary, not mandatory.
toolttime
Morinville Ab Canada
No problems at all for a couple years now.
07 Mandalay 40F
