RV.Net Open Roads Forum: Tech Issues: 1076 LED bulb
 > 1076 LED bulb
tenbear
Northern Vermont, USA
Posted: 04/11/12 08:36am Link  |  Print  |  Notify Moderator
beemerphile1 wrote:
If both contacts make connection they would be parallel not in series. If the lamp is damaged, so what, they are already bought and paid for. I can't imagine any way that they would short and burn a fuse.
One contact would be at 12v, the other at ground. The base would be floating, or possibly at ground. If floating, the 2 parts would be in series, if at ground one segment would light normally, the other would not light.
I don't know how the contacts are aligned with the pins, they are probably the same as the single filament bulb but if not they could cause a short.
Edit: Chris, you are right, I forgot about that.
Class C, 2004/5 Four Winds Dutchman Express 28A, Chevy chassis
2010 Subaru Impreza Sedan
Camped in 45 states, 7 Provinces and 1 Territory
beemerphile1
I'm 57, I'm not a
Posted: 04/11/12 09:39am Link  |  Print  |  Notify Moderator
Deleted post, brain fart.
* This post was edited 04/11/12 11:06am by beemerphile1 *
- Soren Kierkegaard
Chris Bryant
DeLand, Florida, USA
Posted: 04/11/12 09:43am Link  |  Print  |  Notify Moderator
But the 1076 fixture is for a single filament bulb, where the entire circuit is through the two contacts, and the brass housing is not connected to anything.
-- Chris Bryant
My RV Service Blog
The RV.net Blog
tenbear
Posted: 04/11/12 10:31am Link  |  Print  |  Notify Moderator
As Chris Bryant implied, the socket is wired for the 1076 bulb. The socket has two contacts. One contact is at 12v, the other is at ground. The base could be wired to ground or not wired at all. For your suggestion to work both contacts would have to be wired to 12v and the base wired to ground.
beemerphile1
I'm 57, I'm not a
Posted: 04/11/12 11:02am Link  |  Print  |  Notify Moderator
tenbear wrote:
As Chris Bryant implied, the socket is wired for the 1076 bulb. The socket has two contacts. One contact is at 12v, the other is at ground...
I got it now, thanks. I was thinking 1073 which is a single contact. I guess I wasn't paying attention, my apologies.
tenbear
Posted: 04/11/12 11:07am Link  |  Print  |  Notify Moderator
No problem, I'm glad we got it straightened out.
Chris Bryant
Posted: 04/11/12 11:49am Link  |  Print  |  Notify Moderator
It gets confusing, as they do use the dual filament bulbs as well sometimes, for a 3 way 12 volt light. The most common problem is people putting single contact bulbs in the 1076 base- they will fit fine because the base is not indexed (the side tabs are even), but if they are lucky, the bulb will simply not light- or it will short thew two contacts and blow a fuse.
Cajun Bill
Louisiana
Posted: 04/11/12 12:36pm Link  |  Print  |  Notify Moderator
thanks to all for the suggestions. I have received an answer to my email from the ebay seller and I am in the process of taking pics to send to him. I'm hoping he will send me the correct bulbs.
Cajun Bill
Louisiana
Posted: 04/13/12 07:10am Link  |  Print  |  Notify Moderator
Ebay seller could not provide the correct bulbs so he refunded my $$ (except the minimal shipping charges). I now have four 1157 led bulbs that I can't use so if anyone wants them let me know.
 > 1076 LED bulb
