RV.Net Open Roads Forum: Tech Issues: Tire Pressure Monitoring System
 > Tire Pressure Monitoring System
grammygiel
Eagan, MN
Posted: 04/10/12 03:13pm Link  |  Print  |  Notify Moderator
Does anyone have a TPMS that they have had on their RV that they are happy with? We would like one but would like some recommendations first. Thank you.
Dick_B
Palos Heights, IL USA
Posted: 04/10/12 03:19pm Link  |  Print  |  Notify Moderator
Try searching this Forum for TPMS and read on. It has been discussed at length. We have Pressure Pro.
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
powderman426
ohio
Posted: 04/10/12 03:21pm Link  |  Print  |  Notify Moderator
My tire traker seems to work ok. Does both temp & psi. Only down side is taking sensor off to make pressure adjustment. If doing it again I would drill a hole in each rim and add a second valve.
Ron & Charlotte
WD8CBT since 1976
28' Prowler & 05 Ram QC LB
I started with nothing and I still have most of it left
I never fail, I just succeed in finding out what doesn't work
W4MBG
Williamsburg, VA
Posted: 04/10/12 03:25pm Link  |  Print  |  Notify Moderator
i have the system sold last year by pacific duallies, although it was made by tyredog (TD2000A). works perfectly. just replaced 5 out of 6 of the transmitter batteries.
1999 Winnebago Minnie, 29', Triton V10, mostly stock. So far...
Chuck&Gail
In the Colorado Mountains
Posted: 04/10/12 05:08pm Link  |  Print  |  Notify Moderator
Love my Pressure Pro, had it about 8 years now, batteries still fine. Like it so much we added a monitor in daily driver and use sensors from TT on it when not towing. Works great.
Chuck
Wonderful Wife
Australian Shepherd
2010 Ford Expedition TV
Dennis M M
Geneva, IL; Tucson, AZ
Posted: 04/10/12 07:14pm Link  |  Print  |  Notify Moderator
Another vote for Pressure Pro, eight years as well.
'99 Volvo VNL610 - 425 HP Volvo; Super 10 Spd
'11 smart fortwo on Volvo
'05 Newmar Mountain Aire 35 BLKS
Trailer Saver; Bigfoot; Pressure-Pro.
Our Travel Blog - A New Adventure
capndan771
Northern Michigan
Posted: 04/10/12 08:35pm Link  |  Print  |  Notify Moderator
We have been using a TST TM-510 unit that we purchased about 3 years ago at Camping World. It has performed very well. The only issue we noticed is that it seems to monitor at about 2 pounds less than our compressor or tire garage pressure. If we want to register 80# on the monitor we need 82# of pressure via the compressor and messured with a quality tire gauge. Not a difficult adjustment. It gives a great sense of comfort to be able to monitor while traveling and to have a unit that gives you warning if a slow or fast leak is developing while driving. Too many horror stories of blown tires at 70 mph in a motor home!
lanerd
Newport, OR
Posted: 04/10/12 08:44pm Link  |  Print  |  Notify Moderator
Pressure Pro for us too.... going on 5 years now. No issues, except the sticky tape they provide to mount monitor on dash would melt in the sun. Bought one of those table lamps that have the flexible stem and removed the base and light and mounted the monitor to one end and the other to a hole I drilled in the side of my dash and bolted it from under the dash. Now I can move the monitor right over close to me so that I don't have to take my eyes off the road for more than a second. A quick glance and can see all is well.
PP once alerted me to a "0" pressure reading on my right rear tire of the toad. Allowed me to immediately pull off without the blown tire doing any damage to the toad.
Great invention...wouldn't be without it.
Ron
Ron & Sandie
'08 Safari Simba SBD35 CAT C7
Toad: 2011 GMC Terrain SLT2
Tow Bar: Sterling AT
Toad Brakes: Unified U.S. Gear
TPMS: Pressure Pro
Member of: GS, FMCA, Safari Intl, CAT
RETIRED!! How sweet it is....
Home Skillet
Pearland Texas
Posted: 04/10/12 07:44pm Link  |  Print  |  Notify Moderator
I have the SmarTire syetem. The sensors mount inside the tires for true temp readings, unlike the valve stem mount sensors.
Last month I had a front caliper sticking-I could smell the brake pads burning.
I was able to monitor the tire cavity temps, the left side was 160F and the right side was 109F.
2005 Gulf Stream Conquest 31ft
BigFoot Levelers,SmarTire,Bilstein Shocks,Trans temp guage,Lowrace iWAY
Dutch_12078
Great Sacandaga Lake, NY
Posted: 04/10/12 09:07pm Link  |  Print  |  Notify Moderator
Four years on my 10 sensor TST 510 system without any problems.
Dutch
1995 Coachmen Catalina 322QBXL
F53 chassis, 460 V8, TST TPMS
Quadra Bigfoot EZE Levelers
