RV.Net Open Roads Forum: Fifth-Wheels: Jayco "arctic" vs. "polar" packages?
 > Jayco "arctic" vs. "polar" packages?
howardwheeler
West, Texas
Posted: 04/10/12 04:33pm Link  |  Print  |  Notify Moderator
I had a 2009 Jayco Eagle with their Polar package. It had the reflective foil and all the air leak areas on the trailer were sealed with spray foam. It really did seem to be a better insulation job than the other trailers I'd had. Jayco told me at the time I bought the trailer new that that was the first year it was available in the Eagle series but had been in the 2008 Designer. Well, a friend has just bought a 2005 Designer with what is labelled the Arctic package. Do any of you Jayco experts know the differences in the insulation? By the way, the Designer my friend just bought is in very good shape. I generally like the Jaycos. We never had any problem.
Lady Fitzgerald
Tempe, AZ, USA, Earth
Posted: 04/10/12 04:49pm Link  |  Print  |  Notify Moderator
The difference in insulation varies from line to line. In the case of the Eagle travel trailers, in 2011, the Glacier package available for the Eagle fifth wheels was not available for the TTs. In 2012, apparently in response to requests for an Eagle TT Glacier package, the cheap buggers took out the R-7 fiberglass insulation that had been in the roof, leaving only R-14 (so they claim; it was the foil everyone else claims is R-7 if it has an air gap on either side, which the Jaycos do not have) and introduced a Glacier package that. for $140 more, put the fiberglass back in.
I was interested in buying a Jayco a little over a year ago but after the way they have been cheaping out each year since the 2011 models (the above is only one of many complaints I have) and the increase in complaints on the forums I haunt over quality control and customer service issues, Jayco has lost me. At the rate they are going, I wouldn't be surprised to see them go under in a couple of years.
Jeannie
fordsooperdooty
Posted: 04/10/12 07:38pm Link  |  Print  |  Notify Moderator
I like Jayco's too!
The Polar Package has been tested at a continuous zero degrees F. Jayco will not publish it, but their Engineering department told us -10 degrees for long periods of time shouldn't be a problem.
The Polar Package is only an option in the Eagle & Pinnacle Models, not the Eagle SL. However, the SL has R9 Floor, R7 Walls and R22 Roof with the Thermal Pane window option. And it comes standard with the enclosed and heated underbelly.
They usually use the mylar thermal foil (the bubble type) to increase the insulation R-Values.
howardwheeler
West, Texas
Posted: 04/10/12 07:52pm Link  |  Print  |  Notify Moderator
I'm really wondering what the arctic package in my friends 2005 Designer is. Does anyone know how it compares to my 2009 Eagle with the Polar. It worked very well and I'm trying to give him some sense of what he can expect.
fordsooperdooty
Posted: 04/10/12 10:41pm Link  |  Print  |  Notify Moderator
Per the 2005 Jayco Designer Brochure the roof on a 2005 Jayco Designer Series is R-21 Vacuum Laminated, the walls are R-9 also vacuum laminated, and the floors are a R-22 value...which "is achieved by combining R-15 bubble foil insulation and R-7 blanket insulation.
Puncture-resistant PolyFlexâ„¢ and bubble foil insulation line the underside of the flooring. Holding tanks are insulated and heated and the underbelly
is fully enclosed."
At least as good and maybe a bit better than your 2009 Eagle! And if it has dual pane windows...so much the better!
WyoTraveler
Northwest, Wyoming
Posted: 04/11/12 06:51am Link  |  Print  |  Notify Moderator
My Jayflight has the under belly covered with that poly flex and black foam in all the areas to seal off holes. The mice love that foam. Must be good tasting stuff. They have eaten some of it to get in to the under belly. I have had to seal it off with black caulking. They don't seem to like the black caulking as well.
2013 Monaco Monarch motorhome
2012 Jeep Wrangler toad
AC6CV/7 ex-W8RUR since 1954
howardwheeler
West, Texas
Posted: 04/11/12 07:56am Link  |  Print  |  Notify Moderator
Thanks Fordsooperduty. It sounds like the arctic and polar are virtually the same. Maybe it's just advertising techniques but Jayco told me in 2009 that the polar had just been introduced in the Eagle that year and had only been available for the previous year on the Designer. So I thought it was something unique. My experience was the it did work well.
