RV.Net Open Roads Forum: Class C Motorhomes: Risking an older one
 > Risking an older one
Jayco-noslide
Galesburg,Il., USA
Posted: 04/10/12 06:00pm Link  |  Print  |  Notify Moderator
We have had a small 5th wheel for years and still enjoy it but are considering switching to a 25 to 27 ft. Class C or even a similar length Class A. But, like many of you, our income will require one older(early 2000's or even late 90's) How many of you have purchased a motor home with years and miles and how did it go. The last thing we want is to get one that is constantly costing hundreds or thousands for repairs. Our son tried one in the mid-90's for $11,500 but it was a ton of trouble and $$$. Don't know if that was unusual or typical?
Jayco-noslide
pbitschura
SE MN
Posted: 04/10/12 06:32pm Link  |  Print  |  Notify Moderator
Most will tell you what a big mistake you are about to make. Check my sig. Bought this about the time we joined the group and couldn't be happier. repairs, yes. But with good due diligence, the right older vehicle is out there.
1988 Mallard class c 24' Chevy chassis 350 cu gas.
Son of Norway
Denver, Colorado
Posted: 04/10/12 06:50pm Link  |  Print  |  Notify Moderator
Any motorhome you buy, no matter what age, is going to cost you thousands for repairs, maintenance and upgrades. The newer the motorhome, the more they cost. There are a lot of older rigs for sale out there that are in excellent condition and would make a great RV for you. Just start looking.
Miles
Miles and Darcey
1989 Holiday Rambler Crown Imperial
Denver, CO
j-d
Sunny Florida USA
Posted: 04/10/12 06:59pm Link  |  Print  |  Notify Moderator
In the older years, the "Holiday Rambler" units (I put that in quotes because there was also "Alumalite", "McKenzie" and maybe more) offer vastly superior construction unless you get into really rare like the few Airstream motorhomes that looked like their iconic shiny trailer, or the the B+ range like Telstar.
God Bless, jd
2003 Jayco Escapade 31A on 2002 Ford E450 V10 4R100
NewsW
US
Posted: 04/10/12 07:45pm Link  |  Print  |  Notify Moderator
Some age better than others.
Avoid the following:
- full time lived in
- stored in open
- roof / edge made in such a way that water likely leaked in
- expect that appliances are gone, propane system rusted out (esp if exposed to salt)
- generator expect to be gone by hours
- low mileage is a must, say 30,000 to 40,000 miles
- gasoline, unless you are into bus diesel pusher
- watch for electrical system issues... older ones are short / fire prone
- tires over 7 years are toast...
- expect brake job complete.. including reman calipers rotors...
- gas engines and transmissions can be had cheap for swap outs.
Still want one?
Dakzuki
Carnation, Wa, USA
Posted: 04/10/12 08:23pm Link  |  Print  |  Notify Moderator
I bought a 95 in about 2007 and it wasn't bad at all. I had to fix some things while I owned it but nothing major. I knew I was in for tires and batteries when I bought it. During my ownership I had to replace dump valves, charging relay, fix a snotty water heater (plugged jet) and fix the fridge which had been disabled by crud in chimney. Never had a catastrophe and it's still good.
I know lots of folks with older RVs. If taken care of they are just fine.
2011 Itasca Navion 24J
2000 Chev Tracker Toad
pbitschura
SE MN
Posted: 04/10/12 08:25pm Link  |  Print  |  Notify Moderator
NewsW wrote:
Some age better than others.None of this, exept maybe the tires, is true.
- stored in open
Still want one?
None of this, exept the tires is true. Mainenance record will verify .
jerem0621
Sequatchie, TN
Posted: 04/10/12 09:19pm Link  |  Print  |  Notify Moderator
My TT is not a class C but it was full timed in for years. As a matter of fact the PO I bought it from pulled it out from the lot where it lived for years, with a wood deck around it. Lol
I replaced the tires, repacked the wheel bearings, and inspected/repaired the brakes.
All systems work as they should.
If the rig was full timed in you may be suprised to find that most or all of the appliances work as they should.
When they sit, exposed , in the heat and cold with no use, that's when they can go bad.
However if the structure is sound everything else can be brought back at a fraction of the cost of a new one.
I would expect to replace the tires, do a full fluid change, carb rebuild (if equipped), check the propane system, check for water leaks and then go have fun camping!
Don't get discouraged, follow your gut, check your emotions, if something doesn't feel right then do a risk assessment and be prepared to walk on to the next one.
Thanks!
TT: 1995 Layton 2910
Tow Vehicle: 1999 F-350, v10, 2wd, Crew Cab, Dually
Hitch: Draw-Tite Trunnion WD Hitch
Sway Control: Valley dual friction sway control
Brake Control: Tekonsha Voyager
"It's Kind of Fun To Do The Impossible"
~Walt Disney~
PapPappy
Wilmington, NC
Posted: 04/10/12 09:25pm Link  |  Print  |  Notify Moderator
It's a balancing act.....spend money for the newer one, or spend money ON the older one.....either way, owning an RV isn't for the faint of heart or wallet.
If you give it a good check-over and the miles are good, the unit looks well cared for, and they keep maintenance records, you can save a lot of money, and enjoy yourselves in a decade or older RV.
Just be willing to put aside some extra money for the repairs, as they will come along.
Look for any leakage (big item in a "C" cab-over) as well as the tires that were mentioned above. You may want to have the engine checked out, but other than the drivetrain, it's going to be very similar to your previous RV.
Have fun, and good luck
Bill & Claudia / DD Jenn / DS Chris / GS MJ
Dogs: Sophie, Abby, Brandy, Kahlie, Annie, Maggie, Tugger & Beau
RIP: Cookie, Foxy & Gidget @ Rainbow Bridge.
Purchased April 2008 FMCA# F407293
The Pets
Sfla2
fort lauderdale, fl
Posted: 04/10/12 10:05pm Link  |  Print  |  Notify Moderator
not sure what is most important dealer or private, bought mine in 10 its a 98 coachmen c had 29k 450h gen so far lost 1 coil, 1 awning (my fault) & ball joints but it was prv. & we love it just do a lot of searching we did 1 wkend 1000 mi(local State) & this was last i we saw. they are out there just takes time. MUST have all manuarls,also if ur handy can save lot $$$
98 Coachmen "C" Santara Model FL (Front Lounge) 304
Ford v 10
