RV.Net Open Roads Forum: Tech Issues: Im having problems reading my multimeter
 > Im having problems reading my multimeter
judelaurenzo25g
Downey, CA
Posted: 04/10/12 10:59pm Link  |  Print  |  Notify Moderator
I just tested my thermistor using ohms at 2K setting the reading say .549 ohms. Does that mean Its really 5490 ohms? This is what Im testing
A ship in harbour is safe, but that is not what ships are built for.
Wayne Dohnal
Bend, OR.
Posted: 04/10/12 11:07pm Link  |  Print  |  Notify Moderator
The readings are often in k-ohms, so it could mean 549 ohms. Does it change when you heat up and cool the thermistor?
2009 Fleetwood Icon 24A
Honda Fit dinghy with US Gear brake system
LinkPro battery monitor - EU2000i generator
weasel4
Alberta
Posted: 04/10/12 11:18pm Link  |  Print  |  Notify Moderator
Does your multimeter show zero when you touch the probes together?
BTC
judelaurenzo25g
Downey, CA
Posted: 04/10/12 11:23pm Link  |  Print  |  Notify Moderator
yes... It zeros out
judelaurenzo25g
Downey, CA
Posted: 04/10/12 11:10pm Link  |  Print  |  Notify Moderator
No, I tested it before I put it in ice water and it was reading the same.
weasel4
Alberta
Posted: 04/10/12 11:44pm Link  |  Print  |  Notify Moderator
Is there another lower setting on the ohms scale?
Btc
judelaurenzo25g
Downey, CA
Posted: 04/10/12 11:47pm Link  |  Print  |  Notify Moderator
I have a "200"
weasel4
Alberta
Posted: 04/10/12 11:50pm Link  |  Print  |  Notify Moderator
Try that and see what it reads
BTC
judelaurenzo25g
Downey, CA
Posted: 04/10/12 11:51pm Link  |  Print  |  Notify Moderator
this is the multimeter I have
judelaurenzo25g
Downey, CA
Posted: 04/10/12 11:53pm Link  |  Print  |  Notify Moderator
BTC
When i used the "200" setting it would not register anything at all
