weasel4
Alberta
Does it zero on 200 range?
BTC
2oldman
Winchester WA
On my 2k setting that would equal .549 x 2k = 1098 ohm..maybe?
edited 04/11/12 12:13am by 2oldman *
judelaurenzo25g
Downey, CA
weasel4 wrote: Does it zero on 200 range?
BTC
00.0 it reads
A ship in harbour is safe, but that is not what ships are built for.
weasel4
Alberta
You're getting a reading of 549 ohms on the 2k scale. I don't know what the limits are on your thermistor, but one post said it should be around 5k ohms so if you go to the 20k scale it should read in that area if the thermistor is working.
BTC
judelaurenzo25g
Downey, CA
weasel4 wrote: You're getting a reading of 549 ohms on the 2k scale. I don't know what the limits are on your thermistor, but one post said it should be around 5k ohms so if you go to the 20k scale it should read in that area if the thermistor is working.
BTC The range of my thermistor is 8,000 - 10,000 ohms
2oldman
Winchester WA
weasel4 wrote: You're getting a reading of 549 ohms on the 2k scale. Help me out on this. If open circuit is 1. and short is .000, and .549 is 549, then what would 1500ohms be?
SCVJeff
Santa Clarita, CA.
2K= 2000 Ohms full scale.
If you see a reading of .549, that is 549 Ohms on the 2K scale. You can't measure a value that's almost 3 times the resistance value of the 200 Ohm scale.
Jeff - WA6EQU
judelaurenzo25g
Downey, CA
judelaurenzo25g
Downey, CA
SCVJeff wrote: 2K= 2000 Ohms full scale.
so my reading is 549 Ohms? Thats all I want to know really.
SCVJeff
Santa Clarita, CA.
OK, so you have replied with a head scratch on both this thread and the other one you listed above in the last hour. Are you just wasting our time or is there something you don't understand?
Edit: Isn't that what I posted above? We're all trying to also help you understand your meter
Edit again: I have this meter, but not in front of me. The manual I dug out of the drawer claims a resolution of 1 ohm on the 2k scale, so I still think that's 549 ohms, not 0.549, which is a considerably more expensive meter. Yours doesn't start measuring tenths till the 200 Ohm scale, and you said it didn't register there..
edited 04/11/12 12:41am by SCVJeff *
