weasel4
Alberta
"The range of my thermistor is 8,000 - 10,000 ohms"
Then use the 20000 range, and it should give you the true readings of your thermistor if it is working within it's upper and lower range.
BTC
judelaurenzo25g
Downey, CA
weasel4 wrote: "The range of my thermistor is 8,000 - 10,000 ohms"
BTC
Thanks!!! This is exactly what I needed to know. Thank for your patience!
SCVJeff, obviously I didn't understand and if you felt like I was wasting your time Im sorry.
A ship in harbour is safe, but that is not what ships are built for.
byronlj
Arizona
Does this post reflect the accuracy of other information given on this forum? Only 2 in 5 know the correct answer which is a whopping 40%. Maybe some people should only give answers when they are sure they are correct.
Dave
byronlj
07.5 Silverado LTZ Ex. Cab 3500HD dually 4X4 duramax LMM/allison 6spd
07 HR Presidential Suite 37RLQ
SCVJeff
Santa Clarita, CA.
judelaurenzo25g wrote: weasel4 wrote: "The range of my thermistor is 8,000 - 10,000 ohms"
BTC
SCVJeff, obviously I didn't understand and if you felt like I was wasting your time Im sorry. I saw the head scratch on both posts.. The question was what were you really looking at. That I can answer, but not having the spec sheet on the thermistor means you (or me) have no benchmark. Looks like you do now.
Jeff - WA6EQU
elvisdonnelly
Lloyd, Florida
Thanks for the tips guys. It's been helpful.
tvman44
Southwest Louisiana
549 ohms.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
Salvo
California
When measuring resistance, is the thermistor disconnected? It can make a difference.
judelaurenzo25g
Downey, CA
Salvo wrote: When measuring resistance, is the thermistor disconnected? It can make a difference.
Yes the thermistor is disconnected. I followed the instructions that have been posted on this site.
Disconnect, put in a glass of ice water, and test.
judelaurenzo25g
Downey, CA
BTC
I tested it this morning using 2K range and it gave me the same reading 000.59 It seemed to just simply move the decimal over. So if this is true to my range 8K-10K ohms Its not even registering to 1ohm. Either way... I have come to the conclusion that My thermistor is bad.
MEXICOWANDERER
las peƱas, michoacan, mexico
Aggghhhh!
The scale definition is the MAXIMUM limit that scale will measure using the greatest resolution available for that scale setting. In other words, 2M will not resolve to 1.6402 megohms. Your reading of 000.59 is equal to 59% of 1 kilohm or 590 ohms.
Gwt online. Order 10 different 1% metal film resistors. Their resistance won't be exact but close enough. Order 1, 1ohm, 10ohm, 100ohm, and maybe a 330ohm, 1K ohm, etc. etc. and then play around with the scale dial and readout on your ohm meter.
