herburban1
Central,Mass.
I just bought an 07 Yukon XL and have to install the Prodigy. There isn't alot of room under the dash to screw it into and my husband claims he hits his leg on it when it's there. Is there anywhere else I can put it? I can't find the manual to see if it has to be level.
05 Jayflight 29 BHS, 07 Yukon XL Reese Straightline 1200
80 Yamaha Exciter 250
93 Sylvan 17' pontoon
01 Searay 180
Old Town Kayak Otter double "big yellow banana"
Yellow lab Penny rescue from Kentucky, 2 stay at home cats
Ron3rd
Upland, CA USA
The prodigy does not have to be level, or even close to it. You can go to Tekonsia and look at the exact specs, but I think it can be something like 45-70 degrees off level if I recall. You don't want to mount it in an area where you will hit it with your knee as your husband noted. You DO want to mount it where you can get your hand on the lever in a hurry if necessary. I'm sure Chevy owners will chime in with suggestions.
2004 Aljo 250LT
Eaz-Lift WD Hitch
Single Friction Sway Control
Prodigy Brake Controller
Honda EU2000
BobsYourUncle
Surrey, BC Canada
Here is where I put mine on my 07 GMC 3500
It is accessible to manually apply the brakes in an emergency situation and I do not even come close to hitting my leg on it.
Duramax / Allison
Fire Red
1997 Triple E Topaz 27' Bunkhouse TT
81 Citation 25' "Tail dragger" "Under construction"
"Workin' man's rig"
Bob's Trucks
Check Out My Rebuild Project
Project Feedback
CincyGus
Cincinnati
Mines in the same place in my Silverado. I'm 5'11" and don't hit my knee. Must be a taller guy thing ;-)
2011 Silverado Crewcab 4x4
2012 Passport 238ML
Hope your travels are safe and the friendships made camping are lasting.
eric james
Sioux Falls, SD
Mine (in an Expedition) is where the ashtray used to be....
If you want something custom/slick, stop by a car stereo shop.
2009 Keystone Passport UL 290BH
2003 Ford Expedition EB 5.4L/3.73
Chuck&Gail
In the Colorado Mountains
Mine is also where ashtray should be on our Expedition.
Chuck
Wonderful Wife
Australian Shepherd
2010 Ford Expedition TV
Fabguy
Auburn, Washigton
Mine's right next to the ashtray.
Jeff
2002 GMC Sierra 2500HD 8.1/Allison/4:10/Prodigy brake controler/Dual Cam HP
Pulling a 2004 Sprinter 274 RLS
BenK
SF BayArea
Some vehicles have tiny air bags to save the knees/shin from slinding/banging
into the underside of the dash
So, when you folks mount it in front of those tiny air bags...you may have the
brake controller blown into your shin/knees during an accident that sets off
ALL current and future vehicles (cars and trucks, etc)
have to have shin/knee protection from accidents and most OEMs have
molded in depressions on the lower section of the dash
-Ben Picture of my rig
Ron3rd
Upland, CA USA
herburban1 wrote: I just bought an 07 Yukon XL and have to install the Prodigy. There isn't alot of room under the dash to screw it into and my husband claims he hits his leg on it when it's there. Is there anywhere else I can put it? I can't find the manual to see if it has to be level.
"I can't find the manual to see if it has to be level"
To the OP, I checked my manual for my 8 year old original Prodigy (not the P2 or P3) and it can be installed up to 70 degrees up.
BenK
SF BayArea
Notice the knee depressions....DO NOT mount in those loctions
