RV.Net Open Roads Forum: Tow Vehicles: new ram 3500
Search only in Tow Vehicles
 > new ram 3500
rickjf
florida
Posted: 04/11/12 06:52am Link  |  Print  |  Notify Moderator
Hi, looking at brochure for a new ram. its kinda confusing as for 3500, it shows 3 beds, SB, RB, LB. I presume thats for short bed,
reg bed, long bed. I only know of the 6'4" and 8' beds.
but the real issue is the payload. these, with crew cab, and 4X4.
it looks like the payload is only 2680. that seem light.
anyone know?
thanks
Rick & Connie
GMC duramax
Arctic fox 25P
five'er
Canada
Posted: 04/11/12 07:03am Link  |  Print  |  Notify Moderator
2680 is more than a ton. 3500 is known as a "One Ton".. Sounds good to me.
ib516
Up here!
Posted: 04/11/12 07:15am Link  |  Print  |  Notify Moderator
Sounds about right. The GVWR is 10,100#, and the truck will weigh ~7500# (Crew cab, diesel, 4x4, 8' bed, auto trans).
Mine is a little lighter @ ~7250# with the old 4 speed auto and the 5.9L Cummins. So my payload is 2850#.
The short bed is only available on the 1500.
2010 Cougar 322QBS 5er
2007 Dodge 3500 SRW Megacab, 4x4, 5.9L Cummins, 3.73, 48RE auto
HYPERTECH MAX ENERGY or DIABLO PREDATOR tuning
MBRP 4" Turbo back
Scangauge2 for Boost, Coolant temp, Rail press & Trans Temp
Torklift Stable Loads
APT
SE Michigan
I'm not sure where you are getting the info. Dodge/Ram like to combine some information on their trucks between half ton and 3/4 and 1-ton Only the half tons has the short (5.5') bed. HD is 6.5'/8' only.
Payload on the Ram Cummins has always been relatively lower than GM and Ford. Looks like the payload is based on a 10.1k GVWR. I thought they had an optional higher GVWR, but cannot find it. Competitors are in the 11.5k range, with similar curb weight, thus closer to 4000 pound payloads for crew cab 4WDs.
2012 VW Passat TDI
ib516
Up here!
Posted: 04/11/12 07:21am Link  |  Print  |  Notify Moderator
The DRW trucks have a 12,300# GVWR and the payloads are in the 4500# - 5000# range. There is no optional GVWR for the 3500 SRW.
SoCalDesertRider
SanDiego, CA, USA
Posted: 04/11/12 07:54am Link  |  Print  |  Notify Moderator
The 2500 trucks have 9K+ GVWR and are available with-
reg cab and long bed 8'
crew cab and short bed 6'4"
crew cab and long bed 8'
mega cab and short bed 6'4"
The 3500SRW trucks have 10K+ GVWR and are available with-
The 3500DRW pickups have 12K+ GVWR, except for the mega cab, which has 10K+ GVWR, and are available with-
The 3500DRW cab/chassis trucks are available with-
reg cab and 60" cab to axle length, 13,000 GVWR with diesel
reg cab and 84" cab to axle length, 13,000 GVWR with diesel
crew cab and 60" cab to axle length, 13,000 GVWR with diesel
05E350 6.0PSD
98Ranger
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
Callen Camper
92F350 CrewCab 4x4 351/C6
HD Springs Bilsteins,
4.56's & LockRite rear
SoCalDesertRider
SanDiego, CA, USA
Posted: 04/11/12 02:04pm Link  |  Print  |  Notify Moderator
JIMNLIN wrote:
The 5' 7" RB (ram bed) comes on the 1500 only. The 6' 4" and 8" beds come on the 2500/3500 trucks.
Use Ram Body Builders Guide clicky link for the latest offerings for the Ram truck.
The biggest issue with the Ram 3500 SRW low payload is the puny 6200 RAWR the mfg give the Ram VS 7000+ RAWR for a GM/Ford SRW. Thats a 800 lb difference.
Use the clicky link as it has just about all the info you need on weight ratings and other specs.
Yep. That is why, if I were buying a new Dodge, the only Dodge I would buy is the Dually. The 2500/3500SRW Dodge's simply don't have the GVWR, payload capacity and rear axle capacity of the current GM/Ford 3500SRW trucks. Dodge is about 1500 lbs behind in GVWR and 1000 lbs behind in RGAWR.
Dodge needs to get with the program. Quit fooling around with gimmicky engine start/stop and rear air/coil modifications to the 1500 trucks and focus on getting the 2500/3500SRW trucks up to snuff with the other 2 brands. The 3/4-ton and one-ton diesel pickup market is Dodge's bread and butter, as far as trucks are concerned.
And yes, I'm old fashioned. I still call them Dodge.
rjstractor
Auburn, WA
Posted: 04/11/12 02:07pm Link  |  Print  |  Notify Moderator
JIMNLIN wrote:
The biggest issue with the Ram 3500 SRW low payload is the puny 6200 RAWR the mfg give the Ram VS 7000+ RAWR for a GM/Ford SRW. Thats a 800 lb difference. The biggest issue with the Ram 3500 SRW low payload is the puny 6200 RAWR the mfg give the Ram VS 7000+ RAWR for a GM/Ford SRW. Thats a 800 lb difference.
Wow. So the 2500 diesel has a RGAWR of 6000 and the 3500 a RGAWR of 6200. Front axle ratings are the same. So, the next time someone asks the difference between the 2500 and 3500 I guess the correct answer is "1/10 of a ton". I know there is a difference in GVWR, but its the axle ratings that really matter. Makes no sense for the manufacturers to have both a 2500 and 3500 SRW since they are virtually the same save for a few numbers.
JIMNLIN
out here
Posted: 04/11/12 01:02pm Link  |  Print  |  Notify Moderator
anyone know?
thanks
'97 Park Avanue 28' 5er 11200 gvwr two slides
rickjf
florida
Posted: 04/11/12 08:19am Link  |  Print  |  Notify Moderator
thanks all,
 > new ram 3500
