RV.Net Open Roads Forum: Tech Issues: Fridge is toast. New cooling unit?
 > Fridge is toast. New cooling unit?
zedd
Arizona
Posted: 04/11/12 02:29pm Link  |  Print  |  Notify Moderator
The Texan wrote:
... the RV fridge uses MORE electric power than an energy star residential fridge. So don't discount a residential fridge, just because you boondock.
Maybe when it's running on electricity but I run mine on gas when we're boondocking. I seriously doubt that it uses more electric power than a residential fridge, energy star or not. I don't know of any residential fridges that run on gas, altho ISTR there were such units back in the old days. Good luck running your residential unit on batteries. Let us know how it goes.
2008 Ford F250 Super Duty, Lariat, 6.4l PSD, Super Cab. Long Bed
2006 Jayco Jay Flight 27.5 RLS Fifth Wheel
The Texan
Cascade or Meridian, Idaho
Posted: 04/11/12 02:52pm Link  |  Print  |  Notify Moderator
if you have a 12xx Norcold or Dometic RV fridge, you will use MORE electricity than a new Es residential, even if you are on the LP side. The icemaker is old technology, the fridge uses electric to operate the 2 control boards, the burner controls, the defrost mode and the door flap heater. All of this power combined, DC and AC is more than a new Es residential model. When an RV fridge is on straight electric, it is a huge power hog....There are hundreds if not thousands using new Es technology residential fridges while boondocking without any problems. My current solar will allow at least 3 days without any generator use to assist and when I add one more panel or 2 additional batteries, my assit requirements will be nil.
Bob & Betsy(FishNFanatic) - USN Aviation Ret'd '78 & LEO Ret'd '03 & "Oath Keeper Forever"
'05 HR Endeavor 40PRQ, 400 Cummins-Pulling our '11 Silverado LT, Ex Cab 6.2L NHT 4x4, w/2010 Rzr or 01 V Star in back.
Where the wheels are stopped today
recycler
michigan
Posted: 04/11/12 03:03pm Link  |  Print  |  Notify Moderator
if you do the work your self changing out the cooling unit is a lot more cost effective than replacing the whole unit
1968 franklin 11fk
93 d250 cummins
99 f550
UnionMan354
Where We Park It!
Posted: 04/11/12 05:52pm Link  |  Print  |  Notify Moderator
Sorry your having problems with your fridge. Looks like you've been given some good direction here. We recently replaced our cooling unit with a brand New Amish cooling unit after an ammonia leak and near fire.
We have been very happy with our new Amish cooling unit. Since our fridge was from 2000, we purchased the cooling unit package with New fans, fan switch, and AC elements. Oh and we also bought the 'add-on Condenser Baffle' which I think was a cheep & simple device but could help cooling greatly especially with the RV manufacturer didn't baffle the cabinet correctly or is in a slide.
Check out our YouTube video of Shelly & I changing it out: Our Norcold to Amish Built Cooling Unit Change-out
Hope this helps,
Robert & Shelly
2000 American Dream 40' DS
2003 Saturn LW200
Full-timing Class of 2006!
Escapees, ACC/ACA, FMCA Members
http://www.evansrvadventures.com/
11krcford
Sauquoit ny
Posted: 04/11/12 06:40pm Link  |  Print  |  Notify Moderator
Hello it's less labor to replace the refrigerater .my refrigerater when last year and I thought about replacing the cooling unit also.PPL.com out of Texas was the best place to get it from shipped right to your door.Instation was easy less then a hour all done and I'm no mechanic two 12 volt wires gas connection about 6. Screws inside.The hardest part is you need two people to lift it in to place.
Just Lee
California
Posted: 04/11/12 10:12pm Link  |  Print  |  Notify Moderator
I am also having problems with our 12yr old 4 door Norcold. I have tried a number of things my last resort is....
Amish Cooling Unit
I went to PPL and found my fridge (original) for $3100.00... Amish unit $1300.00
If It weren't for flash backs I would have no Memory at all
If you don't stand behind our TROOPS feel free to stand in front of them during a fire fight
2013 View Profile 24G
96 Tracker 4x4 Pushing a Mercedes.
In God We Trust
Texas Two Steppers
Beaumont, TX
Posted: 04/12/12 05:28am Link  |  Print  |  Notify Moderator
I don't think the residential unit would be the way to go for you. I have run the numbers in the past and even with my 4-6v batteries it wouldn't work for me. You would probably need a minimum of 6-6v batteries and it doesn't appear you would have the space. BTW I had my Dometic replaced this summer with the same and it cost about $1,300 total.
2013 Duramax 3500 dually 4x4
2013 Excel Winslow 31RSE
TST tire monitor
Magnum MS 2012 inverter/charger
3-135w solar panels
Tristar controller
Trimetric monitor
4-6v Trojan t105 batteries
B & W companion 3000 hitch
dforce1
TN
Posted: 04/12/12 05:16pm Link  |  Print  |  Notify Moderator
Amish Cooling Unit
Yes, $1325 total for the Brand-new Amish built replacement installed at the factory, that would break down to $1025 for the coils $300 labor=$1325.00
