RV.Net Open Roads Forum: Fifth-Wheels: How fast do you tow your 5'er
 > How fast do you tow your 5'er
Page of 11
usnret
Milledgeville Ga
Posted: 04/14/12 08:44pm Link  |  Print  |  Notify Moderator
I try to stay between 60 & 65, bit sometimes I crepe a little higher. I slow back down to my target speed.
USNRET
Jim & Judy
2009 Ram 3500 Dually LB
2011 Cardinal 3425RT
The Meandering Maddox's Blog
The Call to Serve
"Heaven must need a hero"
BlackSilver
East of Heaven, North of Hell
Posted: 04/14/12 08:47pm Link  |  Print  |  Notify Moderator
I have LT tires on my camper, so no tire-speed limit.
The mileage "sweet spot" on my pickup is right about 63MPH. Below that and the Allison drops down to 5th gear. Above that the MPG drops off a cliff.
Hans, KØHB & Colleen, KØCKB
Master Chief Radioman, US Navy
Prairie Schooner 34FBR Platinum XL Camping Trailer
3500HD Silverado Big Dooley LTZ Go-power by Max & Allie
My rig (Click)
beachram
Delaware
Posted: 04/15/12 07:51am Link  |  Print  |  Notify Moderator
Usually 65mph, but I will speed up to get away from other vehicles. I have found that my 4" magnaflow exhaust discourages other drivers from sitting on the passenger side of my truck when I am getting up to cruising speed.
2007 Sunnybrook Sunset Creek 255RK
2004 Dodge Ram 2500 4x4 Diesel
Equalizer Hitch
Prodigy Brake Controller
hone eagle
essex ontario canada
Posted: 04/15/12 07:56am Link  |  Print  |  Notify Moderator
60 -65 but if Iam getting passed by everybody by a wide margin I will speed up so as not to be 'a rock in a fast stream'
Not a comforable drive but better then being stubborn and a bigger hazard.
2005 Volvo 670 singled freedomline 12 speed
2002 Triple E 30' 5th
coming soon Newmar 34rsks 2008
Hensley trailersaver TSLB2H
Dennis Bham
Alabama
Posted: 04/15/12 08:34am Link  |  Print  |  Notify Moderator
62 MPH when towing - My 2008 LMM Duramax's peak torque is 660 lb·ft @1600 RPM ... At 1600 RPM in 6th gear we travel at 62 MPH. When I set the cruse control at 62 MPH it rarely needs to downshift and gets my best manually measured towing fuel economy of 11.5 - 12.0 MPG.
'08 Chevy 2500HD Duramax 4x4, Crew Cab, Std Bed e/w 18K Superglide
'08 Cougar 292RKS, e/w 16" Sendel wheels & BFG Commercial TA tires
PressurePro TPMS
Devocamper
West Haven CT
Posted: 04/15/12 08:46am Link  |  Print  |  Notify Moderator
65 is where I get my best mpg and also do not feel good about all that weight and mass getting out of control not in a rush when we are towing.Our tire are G's and i think rated for 75mph
08 NU-WA Hitchhiker Discover America 339 RSB
07 Chevy 3500HD LT1 EXT Cab LB DRW D/A
dirt38
usa
Posted: 04/15/12 11:47am Link  |  Print  |  Notify Moderator
Depends whether the slides are in or out.
tomman58
Southeast Michigan
Posted: 04/15/12 02:44pm Link  |  Print  |  Notify Moderator
Interesting what is the torque at 65.
Where do you get this info?
2008 Silverado D/A,CC 4x4 ,3.73,IBC LTZ+
2012 Jayco 322 FKS
2 Trek bikes
Honda EU2000i
It must be time to go, the suns out and I've got a full tank of diesel!
Lifes short enough without bitch'n about it!
sirdrakejr
Las Vegas, Nevada
Posted: 04/15/12 03:14pm Link  |  Print  |  Notify Moderator
My Dodge CTD gets it's nest torque/HP at 1900/1950 RPM. With the setup I have that translates to about 68 MPH. When I towed and now that I carry a truck camper, I get about 12-13MPG at that RPM number. So I try to stay in that band to get the best the engine can offer. Actually the speed from about 65 MPH to 70 is within the narrow band that give me the best I am going to get.
Frank
notruffinit
Minnesota
Posted: 04/19/12 06:36pm Link  |  Print  |  Notify Moderator
Around 65 is good for me. I don't know where that "sweet spot" is for my Ram, but my old Duramax liked it and I did too.
'11 Ram 3500 Cummins
'12 Cameo 34SB3
Page of 11
