RV.Net Open Roads Forum: Fifth-Wheels: How fast do you tow your 5'er
 > How fast do you tow your 5'er
Page of 11
RWalt
Midwest
Posted: 04/20/12 06:58pm Link  |  Print  |  Notify Moderator
We travel between 70 – 74mph on the Interstate and this is equal to 2100 RPM. In a 13 hour day, we can travel 800 plus miles. At this speed we still get 10.25 mpg. In my opinion, you need to drive at what you feel comfortable.
maniac007
South Carolina
Posted: 04/21/12 08:26am Link  |  Print  |  Notify Moderator
I try to stay around 65, Just kinda got used to that speed. After hauling oversized loads up to 14' wide, 14' tall and up to 160,000 lbs. I don't need to get in a hurry.
02 F350SD 7.3 CC DRW, 06 Cougar 314EFS
Too Young to Retire
Sun Diego
Posted: 04/21/12 05:16pm Link  |  Print  |  Notify Moderator
Fast enough to get there. 65-70
Chevy 3500HD Crewcab, SB, Diesel pulling a 36' Cameo
JIMNLIN
out here
Posted: 04/21/12 06:59pm Link  |  Print  |  Notify Moderator
Just came off of a 2872 mile round trip from OK through AR/LA/MS/AL/GA/FL/SC/TN/KY/and MO.
Open hiway speed limits changed from 55 to 75 depending on each state limits and hiway type. I don't have a set speed as terrain and driving conditions/heavy or lite traffic change. However if terrain and not many folks on the road I may drive 75 mph legal limits. I drive any legal speed I'm comfortabe with.
Having a construction business years back with a 1 week-2 week turn around between jobs and maybe a 600-800 mile run to the next jobsite with several trailers on the road, I found out a long tome ago which tires on my trailers worked and which didn't work as advertised.
'97 Park Avanue 28' 5er 11200 gvwr two slides
pawatt
Brainerd MN / Mission TX
Posted: 04/21/12 07:56pm Link  |  Print  |  Notify Moderator
55 - 65 mph
chevor
US/Canada
Posted: 04/21/12 08:07pm Link  |  Print  |  Notify Moderator
I usually range from 50mph to 65mph depending on the winds and hills. When I pull a trailer I drive with respect for the road and the weather in that area.
2010 Gmc 2500 Duramax,1ton rear springs, 90g box tank, 0ver 497,500 Odometer miles, 20k Curt fifth wheel, 18k Curt rear mount hitch. Cobra CB/Weather Radio, Bridgestone Duravis R500 HDs Rancho 9000 Shocks, Firestone Airbags, bypass oil filter, Fass 95HD
Page of 11
