RV.Net Open Roads Forum: Class A Motorhomes: Why separate holding tanks?
 > Why separate holding tanks?
Page of 5
Rich D.
New England
Posted: 04/12/12 08:02am Link  |  Print  |  Notify Moderator
My recollection is that late 60's and early 70's RV's had a black tank only. The grey water just dumped on the ground. In the mid 70's another tank was added for the grey water. Most all manufacturers have been supplying two tanks ever since. Some run a sink into the black tank as the plumbing layout (floorplan) makes that eaiier.
Two tanks do have some advantages as stated by posters here, shower backup, hose rinse, etc. Ideally the set up of a two tank system would include a designated grey water transfer pump to occasionally add grey water to the black tank if necessary. This would let the RVer manage the tank capacities to suit the situation.
Rich D. Wanderlodge M450 LXi
ArchHoagland
Clovis, CA, USA
Posted: 04/12/12 09:35am Link  |  Print  |  Notify Moderator
I don't have two tanks. I've got four tanks.
Two gray and two black.
2004 Monaco La Palma 36DBD
Workhorse W22 8.1 Gas Allison 1000, 7.1 mpg
US Gear Brakes
Nothing is either good or bad, but thinking makes it so.
wa_desert_rat
Central Washington State
Posted: 04/12/12 09:40am Link  |  Print  |  Notify Moderator
This is my recollection as well. In fact, we own a 1972 Streamline Princess with only a black tank; grey water just runs out. We put a 5-gallon bucket under it.
Craig
kidkasha
Ventura County
Posted: 04/12/12 09:56am Link  |  Print  |  Notify Moderator
Is it possible to dump grey into black if grey is full and black pretty empty, and how.
roadweary
southern Utah
Posted: 04/12/12 10:24am Link  |  Print  |  Notify Moderator
Nice! How much capacity?
Rich D.
New England
Posted: 04/12/12 10:45am Link  |  Print  |  Notify Moderator
Simple, install a designated waterpump drawing from a low spot on the gray tank and pump it to the top of the black tank. Install a check valve at the outlet by the black tank to prevent backflow. Run your pump and watch guages/lights for the black level rise and the grey lower.
SRT
Head of the Lakes, MN
Posted: 04/12/12 11:30am Link  |  Print  |  Notify Moderator
Our motor home has 2 40 gallon tanks - one for gray water and the other for the black water. With just two of us our black tank has gone 10 days. The gray water about 7 days.
SRT
2000 32' HR Vacationer with Banks
1998 Subaru Outback Ltd. 5 spd
Brake Buddy & Blue Ox Aventa II tow bar
FMCA #266040 HRRVC #84109
ClassAGeek
NYS
Posted: 04/13/12 06:03am Link  |  Print  |  Notify Moderator
That solution would satisfy customers on both sides of this issue. With so many manufacturers looking to distinguish themselves, few have this option. In fact, are there any aside from DIY'ers?
Happy Ford F-53 Class A Owner (2008 Gulf Stream)
2010 Ford Fusion Toad (with 6 speed manual transmission - the only way to tow)
Brake Buddy Vantage, Blue Ox Aladdin Tow Bar,
TST RV 507 TPMS, Power Master Voltage Controller
1995brave
San Antonio, TX
Posted: 04/13/12 12:08pm Link  |  Print  |  Notify Moderator
My Winne has three, two gray(one shower), and a black. When i dump i hook up the hose and open and close the gray valve just to check the hose for leaks. Then i pull the black, then the gray, and then the shower.
Old-Biscuit
Across the USA
Posted: 04/14/12 11:50am Link  |  Print  |  Notify Moderator
Easier still......
Just install another valve on main drain line. Leave it closed, open both tank valves and let tanks equalize.
You an even purchase a 'twist on' valve for end of drain line.
Page of 5
