RV.Net Open Roads Forum: Travel Trailers: So what will happen..?
 > So what will happen..?
Page of 7
N7SJN
SE Washington State
Posted: 04/16/12 04:43pm Link  |  Print  |  Notify Moderator
We had a 1/2T and now a 3/4T. For my peace of mind I like the 3/4T, the 1/2T worked OK but I just didn't like the lack of power towing the same TT thru the same mountain passes. BTW milage is the same between the 5.3 and the 6l engines.
HappyTrails2U2
Tennessee is home but being held hostage in GA.
Posted: 04/17/12 06:36am Link  |  Print  |  Notify Moderator
Bucky Badger wrote:
I'm trying to figure out how a HD tow package would only have a 3.42 for a rearend
That's because it has a 6 speed automatic transmission so it doesn't need the bull dog gear of yesteryear trucks.
The original poster is worried a bunch about nothing. His truck is supposed to be a lot more powerful than my 2003 Silverado and I tow a lot bigger trailer than he does without any problems.
2010 Rockwood Signature Ultra Lite 8315BSS
2003 Chevy Silverado 1/2 Ton Extended Cab
cjoseph
WV
Posted: 04/17/12 08:14am Link  |  Print  |  Notify Moderator
I agree that you are just at the limits maybe over some/one or maybe none. I also agree that I wouldn't trade the truck or trailer, either.
I would get good weights and use them to determine what might be capable of upgrading and what may break first.
Example: you may be exceeding the tire's weight limits. That's an easy fix without losing your shirt. You could upgrade to LT (if running Ps). Rotate the Ps back on during the winter when you're not pulling the TT. You're not really out anything, but in a more safe situation.
You might find that the only bad number is the tongue weight. Maybe rear axle. The point is, you don't know until you get to the scales. They will tell you where you can adjust and where you should be more attentive.
Maybe the scales will tell you to go ahead and keep doing towing just as you have been, and you will have a little more peace of mind.
Chuck, Heidi, Jessica, Nicholas & Tan Puppy
2008 3/4-ton Yukon XL, Flagstaff 831BHSS
Equalizer Hitch and Prodigy
scottsnider
Buena Park
Posted: 04/17/12 09:58am Link  |  Print  |  Notify Moderator
One rule I learned long time ago, keep the trailer (loaded) under the weight limit by 1000lbs and you should be fine. Has always worked for me.
PaulandMonica
Victoria B.C
Posted: 04/17/12 10:32am Link  |  Print  |  Notify Moderator
I pull with a 2010 silverado with the same tow package etc.Our trailer weighs in at about 6400lbs loaded and is 29 feet overall. The truck is rated for 9600lbs.We are well within all limits and it does o.k. Sure it slows down in the mountains and with a stiff head wind but no real complains. I think you will be just fine as long as you don;t overload.
Page of 7
