RV.Net Open Roads Forum: Fifth-Wheels: LT Tires
 > LT Tires
larry barnhart
wenatchee. wa usa
Posted: 04/13/12 09:18am Link  |  Print  |  Notify Moderator
The Michelin story was they do not advise a passenger car tire on a fifth but as was said DRV uses a Michelin J tire. never saw a J tire on a car so the story continues. We are on our 2nd set of G 614's and the alpenlite came with G-159's with no tire problems yet but I do take care of them. Not hitting the curbs or running with low air pressure seems to help. I also keep the tires over 110 lbs when sitting. I did read the weight of tires and some are very low as the duro's on the carriage E tires. Nothing but a rag I think.
chevman
chevman
2001 35 ft avalon alpenlite RK
prodigy
easyrider/reese airhitch
trailair center point suspension
JT Strong Arm Stabilizers
KSH 55 inbed fuel tank
Garmin 2720
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
45Ricochet
North Idaho
Posted: 04/13/12 10:48am Link  |  Print  |  Notify Moderator
They will serve you well.
06 Ram 3500 CC LB Laramie 4x4 Dually 5.9 Cummins Smarty Jr 48RE Jacobs brake
GVWR 12,200 RAWR 9350
06 Grand Junction 34' High profile 15500 GVWR 3200 pin Mor/ryde 5500 Onan genny Dual A/C Wet bolts
27' Hallett 502, 500HP
FastEagle
Taylors, SC
Posted: 04/15/12 08:34pm Link  |  Print  |  Notify Moderator
me2 wrote:
I put cheap generic rebranded LT265/75R16s LREs on our 2011 Chaparral 355. They have a load rating of 3420 lbs, just like any other LT265/75.
The trailer weighs about 13K. I pulled it a bunch last summer with zero problems. I am very happy I did so.
I hope you have the right rims. The minimum rim width for those tires is 7".
FE
New Post - 4-30-2013
steelpony5555
Copperas Cove Texas
Posted: 04/15/12 08:44pm Link  |  Print  |  Notify Moderator
I think the Michelin article is BS since a lot of higher end trailers come with LT's right from the factory. My Alpenlite came with Goodyear Wranglers on it...It's right on the yellow side sticker, LT tires.
06 Montana 3000RK
07 Dodge 3500 Dually Sport 6.7 Diesel
07 Pearl White Ultra Classic (My new Baby)
10 Chrysler 300 Touring
Texas Boomers---Stop by for a Margie some time!
joebedford
Jasper, Ontario
Posted: 04/13/12 11:24am Link  |  Print  |  Notify Moderator
mguay wrote:
From what I've read here...failure rates are somewhere like 80% China Bombs, 30% G614s and minimal LTs.
On my old trailer, the failure rates were 100% China Bombs, 100% LT, 0% G614s.
Current trailer 0% China Bombs (10000 miles so far)
2011 Silverado 3500HD LTZ CCLB 6 x Michelin LTX MS2 80 psi
2011 Voltage 3950 6 x Bridgestone Duravis R250 80 psi
2004 H-D VRSCB(mine)
1996 / 2007 H-D / DFT FLHTCUI Trike(hers)
2004 Thor Dutchman 35SRV traded
2004 Dodge Ram 3500 5.9 CTD traded
me2
Wherever
Posted: 04/13/12 12:23pm Link  |  Print  |  Notify Moderator
 > LT Tires
