monza66mo
Missouri
I have a Travel Light 840SBR that is 4 years old. The two passenger side eye bolt tie downs broke completely off right at the nuts. I can't remove what's left of the remaining threded shank or nuts. Do I have to remove the exterior shell to get access to the top of the bolt/nuts in the frame of the camper? Would it be safe and secure to drive in eye lag screws next to where the broken eyebolts were? I'm taking the rig to Montana next month (1650 miles) to get a stabil-lift system installed but I gotta make good and sure that I secure the TC to the truck.
Art in Missouri
2008 Travel-lite 840SBRX
2008 Chevy Silverado 2500
Farmerjon
Niangua, missouri
If the manufacturer is still around I would call them and see what they suggest.
00 F350 SC LB 4x4 DRW 7.3 PSD 6sp 3.73 DYI over load bumpers
99 Starcraft 953
87 F250 460 4x4 4sp 4.11 ex cab 8ft
95 jeep YJ 4cyl 5sp
69 f250 360 4sp
SoCalDesertRider
SanDiego, CA, USA
You may be able to access them from the inside through a cabinet space or appliance space.
I would not use a threaded lag eye bolt in to the wood. The tie down eyelets really do need to be secured into some kind of backer inside the camper in order to not pull through or break whatever they're screwed into.
An alternative, if you cannot access the inside at all, would be weld a reasonable size piece of steel angle, like say 2x2x3/16, spanning from the front jack bracket to the rear jack bracket, then weld hooks to the bottom of the angle, drill some holes in it and lag screw the angle into the bottom and side of the camper in a few places.
05E350 6.0PSD
98Ranger
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
Callen Camper
92F350 CrewCab 4x4 351/C6
HD Springs Bilsteins,
4.56's & LockRite rear
big whitey
raleigh,nc
Farmerjon wrote: If the manufacturer is still around I would call them and see what they suggest.
X2 on contacting the mfg.on the flip side hope you have thoroughly researched the stable lift and are comfortable with the cost,functionality,limitations,etc of the stable lift.it would not work for me as most of my trips are off road .GLTU,hope you get your eyebolt issues resolved.
niftypkg
Arizona
Yes, look for the remainder of the eye bolts in a cabinete or under the seating. I have access to two in those locations. At the same time you might want to go to a heaveier bolt and fender washer.
niftypkg
Arizona
billtex
RI
You did not give a lot of info here...and some pics would help...I would seriuosly consider looking around for other (water?) damage on this camper before you invest in a $tabil lift...
Good luck,
Bill
2006 Chevy D/A CC
Adventurer 810WS
25'Airstream Excella
"Good People Drink Good Beer"-Hunter S Thompson
joe b.
A drill bit and an E Z Out tool, might be able to remove the broken bolt that remains. Then replace the bolt with one the same size but preferable a better quality bolt.
http://www.amazon.com/piece-Easy-Screw-B........ref=sr_1_9?ie=UTF8&qid=1334239794&sr=8-9
joe b.
Stuart Florida
Formerly of Colorado and Alaska
Chevy 3500 DRW Dmax CC - Rockwood 8281 SS 5th Whl & 2008 Lance 845 TC
www.pajbcooper.com web site
Alaska Trip 2011 posted
Colo-Utah-Ariz 2012 trip posted
"Without challenge, adventure is impossible".
d3500ram
colorado
I would not recommend lag eyes. I did that and they pulled out. I ended up pulling the water heater out to gain access to the area on a past camper to re-do the tie downs.
2005 Dodge 3500 SRW, Qcab long bed, NV-6500, diesel, 4WD, Helwig, 9000XL,
Nitto 285/70/17 Terra Grapplers, Honda eu3000Is, custom overload spring perch spacers.
2008 NorthStar Arrow short bed.
ticki2
NH
Since you are going to the stable lift system this is going to be a temporary fix . All the tie down eye bolts will probably have to come off to install the stable lift . How about using heavy duty load straps hooked to the jack mounts and the truck tie-downs for the one-way trip. The jack attachments are good for about 2000# as apposed to the original eye bolts which are meant for maybe 300# .
'68 Avion C-11
'02 GMC DRW D/A
