RV.Net Open Roads Forum: Technology Corner: Outside TV LCD or LED
 > Outside TV LCD or LED
DD716TED
Washington State
Posted: 04/11/12 08:40pm Link  |  Print  |  Notify Moderator
I want to replace the older CRT TV that we use outside of our TT... Which Flat Screen TV (24 to 32") will give better picture (brightness) and performance in outdoor conditions.. a LCD or LED?
skipnchar
Topeka or somewhere else
Posted: 04/11/12 10:03pm Link  |  Print  |  Notify Moderator
Either one should work about equally well.
Goldencrazy
madison wi
Posted: 04/12/12 08:02am Link  |  Print  |  Notify Moderator
LED is going to be lighter weight and thinner. You can control the backlight on either but I prefer the LED. It is also a bit more expensive. Where weight can be an issue LED is better. Also takes less power so if operating off inverter on battery that may be a consideration.
Charltons
Battle Ground, WA
Posted: 04/11/12 11:51pm Link  |  Print  |  Notify Moderator
X2...either will give about the same outdoor viewing experience.
2012 Dodge Ram 2500 Crew Cab 4X4 TCD
2012 Keystone Sprinter 311BHS
cooper841
Maryland
Posted: 04/12/12 04:24am Link  |  Print  |  Notify Moderator
The only problem I have sometimes the glare from the sun.
Dana & Julie Cooper
Kozy & Pierre
2007 Fleetwood Fiesta LX
2003 Harley Fatboy mighty hauler lift
2010 Kia Soul
CincyGus
Cincinnati
Posted: 04/12/12 04:56am Link  |  Print  |  Notify Moderator
Some TV's have better antiglare features than other. That whould be my main search criteria if I were looking for an outdoor TV.
Might check out this links for some info:
outdoor TV
From a quick search on google it looks like the "OUTDOOR" TV's are quite expensive because they are often waterproof and meant to be permanently outside. This is probally overkill for your application.
Might look at some of the aftermarket anti glare kits that you can put on any TV to help reduce the glare. Seem much more reasonable.
2011 Silverado Crewcab 4x4
2012 Passport 238ML
Hope your travels are safe and the friendships made camping are lasting.
DD716TED
Washington State
Posted: 04/13/12 03:26pm Link  |  Print  |  Notify Moderator
Thanks for the heads up about sound.. Never considered it..
sch911
Rochester Hills, MI
Posted: 04/12/12 09:10am Link  |  Print  |  Notify Moderator
FYI: LCD and LED are the SAME! Both are LCD displays, the only difference is that LED uses LED's as the backlight source....
Chrysler/Dodge/Ram/Jeep Engineer
2003 Damon Challenger 348 Class A - F53 Triton V10
BB_TX
McKinney, Texas
Posted: 04/12/12 09:22am Link  |  Print  |  Notify Moderator
and LCD uses flourescent light bulbs as the backlight source.
As mentioned, for outdoor use screen glare is more likely an issue than light source.
LCD vs LED
mikestock
Vestavia Hills, AL, USA
Posted: 04/13/12 01:52pm Link  |  Print  |  Notify Moderator
Before you buy, take a listen. I bought a Toshiba 32" with the intention of using it outside at football tailgates. It has a good picture but the sound is so weak there was no way to hear it over the ambient noise. Bought a sound bar but this tv doesn't even have and audio out hook up. Had to run audio output from my DirecTV receiver to the sound bar. Just something to keep in mind when shopping. Some of these super thin tv's may have a compromised sound system.
2005 F250 Crew Cab LWB Power Stroke, 2007 Montana 3500RL Fifth Wheel,Honda EU3000IS, Twin Honda EU2000i's, S&W security system
