RV.Net Open Roads Forum: Class C Motorhomes: Furnace and Heating
 > Furnace and Heating
jpopular2
California
Posted: 04/11/12 08:42pm Link  |  Print  |  Notify Moderator
Have a 22ft Honey motor home on a Ford bed. Anyway New to all of this so don't understand the LP system?? Once The LP is turned on do I need to or is there a polite I need to lite for the heater? Is there a separate polite for the Hot Water? Is there a LP meter to show full or empty? Any help would be appreciated. The unit ia a 1989
pianotuna
Regina, SK, Canada
Posted: 04/11/12 08:48pm Link  |  Print  |  Notify Moderator
Hi,
It may be best to ask just one question per thread.
If it is a ducted furnace it likely has a spark type ignition for the burner.
Some water heaters require lighting a pilot, and others work in a manner similar to the furnace.
There are sometimes pressure gauges on propane tanks but this is not a particularly reliable way to know how much fuel is left in the tank.
Regards, Don
Kustom Koach Class C 28'5" 256 watts Unisolar, 875 amp hours in two battery banks 12 volt batteries, 2500 MSW watt inverter.
2oldman
Winchester WA
Posted: 04/11/12 09:05pm Link  |  Print  |  Notify Moderator
Polite? I guess you mean pilot.
Old-Biscuit
Across the USA
Posted: 04/11/12 09:39pm Link  |  Print  |  Notify Moderator
Propane tank has propane in it?
Propane tank valved in?
Battery(s) charged....good voltage?
Yes......
Set thermostat to 'heat'......set to desired temp. and listen for furnace fan to come on. The fan needs to run a short time to purge chamber/make up sail switch then igniter spark should happen and gas valve opens......fire----then warm air.
Water heater......full of water?
Yes.....propane only----turn on switch for water heater. Igniter spark..gas valve opens......fire------hot water in about 20 minutes.
Unless it has a pilot.....then open outside compartment and lite pilot then turn gas on.
skipnchar
Topeka or somewhere else
Posted: 04/11/12 10:01pm Link  |  Print  |  Notify Moderator
It is possible that your LP appliances have pilot lights or they could have DSI (direct spark ignition) which lights them electronically. IN an 89 model year I would suspect that DSI would have been an option that the original owner may or may not have chosen. Really no way for anyone to tell unless they happened to know model numbers and you gave them the numbers. If you look outside in the service panels for the water heater you may be able to tell. There should be lighting instructions on a tag inside the service panel if it has a pilot. Same thing for the furnace. No instructions, they are PROBABLY DSI models. If they have DSI then all you do is turn them on with a switch located inside the RV or from the thermostat (in the case of the furnace).
rockhillmanor
On the Road
Posted: 04/11/12 10:20pm Link  |  Print  |  Notify Moderator
I'll just add that unless you are boondocking, which is parking with 'out' hookups, you will quickly find out that an electric ceramic heater will heat your MH up better than the furnace AND without all the on and off and noise from the furnace blower.
I heat a 31 ft with a ceramic heater, I never use the furnace.
A ceramic heater in your 22 ft will roast you out and you won't have to worry about running out of propane for the furnace which if you run it all night will most likely only last one day!
"We must be willing to get rid of the life we've planned,
so as to have the life that is waiting for us".
pianotuna
Regina, SK, Canada
Posted: 04/12/12 05:02am Link  |  Print  |  Notify Moderator
Hi rockhillmanor,
Do you mean the battery will only last one day? Propane should last considerably longer than a day.
I do try to heat electrically as much as is possible but prefer small oil filled heaters that I can "spread around" the rv.
I've modified my cold air return with a thermostatically controlled dual window fan that allows some air to circulate through the duct work. This nicely takes care of fresh water freeze ups.
