vatchley
home
We have a 2006 mallard fleetwood. Tried to turn on heat last night and it was blowing cold air. Then the refrigerator would go off and try to relight.We were dry camping. It seems like the furnace was causing the fridge problem? Checked the fuse and it looked okay. Where do I start?
kaydeejay
SE Michigan, USA
Propane supply?
Keith J.
1999 Sunnybrook 27RKFS Fiver.
2005 GMC Sierra 2500HD CC/SB/DA 2WD, LBZ air cleaner, 52 gal Titan tank, Bilsteins, Line-X, Westin steps, Prodigy, Retrax cover, 16K Superglide, 5th-Airborne pin-box, Multi-vex mirrors, TST TPMS.
Chuck&Gail
In the Colorado Mountains
Dry camping? How many batteries do you have? We get one night per battery when using furnace. Mostly dead battery will cause what you describe, as will no propane.
Chuck
Wonderful Wife
Australian Shepherd
2010 Ford Expedition TV
Old-Biscuit
Across the USA
Both appliances need good 12V DC voltage to operate controls and furnace fan.
Both appliances need good propane supply to operate when dry camping.
Even though furnace fan was running and blowing cold air it has to run fast enough to cause 'sail switch' to make up before igniter/gas valve can operate.
If you have good supply of propane.....haven't run out or forgot to valve in both tanks etc. then I would suspect your battery(s) have low voltage and need recharged.
pulsar
Lewisville, NC
Moved from Forum Technical Support to Tech Issues.
dougrainer
Carrolton, Texas
Light all the burners on the range top. Turn on the Furnace and/or the Water heater on LP. Watch the range burners and IF they diminish or almost go out you have a defective LP regulator as long as you have ample LP in the tank. Do NOT try to adjust the regulator. It will not adjust correctly. Just replace it. Doug
Cool Canuck
Winnipeg, MB, Canada
Sounds like a propane supply to me as well. If there is propane in the tanks and they are turned on, the protection valve may have closed. Close the tanks (you might hear a click) and then reopen them slowly allowing the lines to pressurize.
04 Everest 343L
2011 F250 PSD CC
SOLD - 01 F250 PSD S/C S/B
SOLD - 00 Jayco 313
bushman512003
wallaceburg,ontario,canada
Check the Batt.low voltage no heater no fridge I would bet on the batt.being low
Keystone 5er Model Cougar 276 RLS ,and all the toys.Enjoying camping,friends, fire. LOL. life is good..John,Jeannette,..From Canada the Queen's Country..Member of IRV2.Com. The Bushman EH!
joeprinter
Fayetteville, NC
Just a thought, higher altitude will make the propane, act different. If that isnt it, then I suspect the regulator as well.
"2012 Forest River 360 DS"
"Ford V-10"
"2013 Toyota Corolla on Tow Dolly"
vatchley
home
We thought the tanks were half full. Battery was charged. Are checking tanks today. Thanks
