brinasmemaw
southern Oklahoma
I am sure someone here can help me figure out this problem. We are getting ready for a trip to Alaska & as I began to check everything out I found that the furnace, when igniting, has an "explosive" sound. The best way I know to explain it is that it sounds like the propane runs too long prior to the ignitor doing it's thing & then when it all comes together it makes a loud poof sound or like gasoline when thrown on an already burning fire. If anyone has any ideas as to what this might be or how to fix it I sure would appreciate the help. I plan to take the orfice out tomorrow & see if I can see anything wrong there but just thought I'd start picking you guys brains for help. Thanks, Mac
edited 04/14/12 01:42pm by brinasmemaw *
Mac & Becky
Seeing North America one mile at a time
2006 42' Allegro Bus towing a 2011 Cadillac SRX
2011 F350 6.7L Crew Cab FX4 & 2005 Holiday Rambler Alumascape for Alaska trips
c.traveler2
Moreno Valley,Ca.
Frist,If the furnace has a spark igniter what lites the pilot first,then the main burner you may need to adjust the spark/pilot closer to the main burner. I have found this problem on many residential units, over the years the metal holding this assembly can warp and move out further from the main burner causing that effect. Check it and correct it before too much propane pools up then ignite causing more than a small pop.
Second, if it's direct spark ignition there could be too large of a gap and it's not jumping the gap till some gas gathers, same effect and small pop noise. Both conditions are undesirable and very dangerous.
edited 04/12/12 01:09pm by c.traveler2 *
2007 F-250 4x4 /6.0 PSD/ext cab/LB/camper pkg..Lance 815/ 85 watts solar panel
Travelingman2 Photo Website
Truck Camper Trip Reports
Grillmeister
BBQ TOUR USA
eHoefler wrote: I would look inside for an obstruction, ie: wasp or spder nest.
When mine did the same thing you are describing I found upon dismantling it a large mud nest in the air intake tube!!
Please let us know the outcome.
Show me the GRILL and STAND BACK!!!!
rkentzel
California
Your having whats called delayed ignition which you need to resolve asap.
2002 Toyhauler Forest River
Turbo Diesel Dude
Green Mountain, NC
Sounds normal to me. I turn on my furnace and after a short wait, it also makes a popping/roaring sound and I'm still here alomg with my DW and cat and TT.
charles weidman
eHoefler
ozark mountains
2010 Ram 3500, Crew Cab, Long bed, 4 x 4,Dually, Lights & Siren!
2006 40' Landmark Mt. Rushmore
brinasmemaw
southern Oklahoma
Mac is still out working on the furnace but asked me go ahead & post that he did find all parts of the furnace FULL of dauber mud. Of course it was all caked & hard as a rock so he had to use several different methods of removal but he did get them all out & no explosive sounds now. Thanks for the help everyone. He has another question regardling the orfice but I will put it in a different post for max exposure. Thanks again!!
jetcare
RV Repairman - South Fork, CO in the summer
You need to look closely inside the combustion chamber area for mud-daubers. The explosive sound is not correct. Many times, I find mud-daubers way inside and have to remove the entire furnace to wash out the nests. Sometimes they get very hard and cannot be removed with compressed air. I use a powerful light and mirror to get a good look inside the furnace.
Matt
A-1 Mobile RV Services
2007 Coachman 32 foot Travel Trailer
2010 Ford F350 Super Duty 4X2, SRW, 6.4L
Chris Bryant
DeLand, Florida, USA
It could be a number of things- bad board, bad electrode, bad burner, need cleaning.
-- Chris Bryant
My RV Service Blog
The RV.net Blog
brinasmemaw
southern Oklahoma
Thanks for the postings so far & as soon as I can figure it out I will let everyone know what I found. I am not at all comfortable with leaving as is, just doesn't sound like it should at all & I too feel it could be dangerous. Mac
