bts1985
Land 'O Lakes
I have a Itasca Navion that I tried to get a front end alignment done and was told that the chassis are set up for a slight pull to the right. Is this true? Will a perfectly aligned RV still always drift to the right? Or is this only an issue with the Sprinter chassis?
Kamphiker
South Florida (this 'aint paradise anymore)
NO!
should track straight regardless of the chassis.
You will get a slight drift to the right if the road surface has a "crown" to it.
Another cause would be a side wind due to high profile.
A proper setup alignment will track True.
Perhaps there are unique settings to the sprinter alignment that the shop is missing.
2006 Winnebago Outlook WF324V
2009 Honda CR-V 2wd TOAD ......Campgrounds in the Smoky Mountains NP
Last Camping trip ->2011 SUMMER SMOKY MOUNTAINS NATIONAL PARK
halibutman214
Oregon
bts1985 wrote: I have a Itasca Navion that I tried to get a front end alignment done and was told that the chassis are set up for a slight pull to the right. Is this true? Will a perfectly aligned RV still always drift to the right? Or is this only an issue with the Sprinter chassis? I can't fathom this being true but stranger things have happened. I've driven 3 Class C quite a bit and none of them pulled at all. My question to whomever told you this would by, WHY?
2008 Dodge Ram 6.7 Laramie SRW SB
2012 Keystone Passport 26BHWE
2009 Lance 830 with Tent foldout
20' North River Seahawk Boat
2005 Honda VTX1300
donn0128
Pronounced Ore-gun
Where did you get that piece of misinformation? I certainally would not trust their alignment skills after a comment like that. Because of the crown in most roads, it should be set to pull very slightly to the left on a perfectly level surface. Since there is no such a thing most vehicles are set per factory specs, meaning to drive straight. Loading, especially on a motor home chassis can effect that a lot.
Donn,Lorri,Max (The Rescued Lab)
Resident Know It All
bts1985
Land 'O Lakes
I was told by the "experts" at Lazy Days in Seffner Florida that my coach and all RV's and heavy trucks are all set up to pull to the right by the manufacturer. When I first complained that the coach wouldn't track properly they said it was road crown. Then that changed that to the wind, then oversteering, then the final insult was that the truck was designed that way. This happened of course after I had paid, test drove and came back to complain. Anyone else every handed this story?
fla-gypsy
North Florida
That sounds like pure horse hockey from incompetent technicians to me.
Ductape Dave
New Jersey, USA
Did you try contacting the chassis manufacturer's customer service rep?
bts1985
Land 'O Lakes
LOL! That's what I said. I was very pleased with their other work. I don't understand why they would say something like that and ruin my whole experience with them along with their reputation.
Dave - I have considered contacting Dodge. I haven't found anything similar online when I research Sprinter issues.
1995brave
San Antonio, TX
The only time mine tries pulling to the right is when i'm coming up to a gas station or an RV park.
doc brown
Redondo Beach, CA,
Makes no sense to me! So that means you have to turn and keep the steering wheel to the left to stay straight on the road? That's not a correct situation at all.
Steve,Kathy,Josh & Morpheus the Basenji
2004 40' TSDP Country Coach Inspire DaVinci
350 Cummins, 3000 Allison
2008 Wrangler X Rubicon/Blue OX Tow Bar/Ready Brake
