atomlinson
Hebron, KY
As stated already, avoid all grease going down your drain. Warm grease will harden, and will stick to pipes, just like at your home. Also when you empty out at the dump station, you introduce your grease to the cg's sanitary sewer system, which may over time develop a blockage in their sewer lines as well. I work for the local sewer department, and have had the unfortunate pleasure of cleaning out stopped up sewer lines due to grease blockages. Nastier than "poo" by far! Just keep as much grease in your garbage can as possible, and out of your drain.
Andy
2012 Keystone Outback 280RS
2003 Chevy Silverado 1500HD
campn4walleye
Central WI
Use your napkins or paper towels to wipe the big stuff off your dishes before washing. I know that sounds silly, but you'll keep your tank a lot cleaner and be assured that the least amt of grease is going in. Also, try to use the least amt of soap that will still clean. This will ensure that your tank will last yrs without problems.
2011 Adventurer 910FBS,Torklift tie downs,Fastguns & Wobbl-stopprs
2012 Dodge 3500 DRW 6.7L CTD, 4x4, LB,CC,6 speed auto,3.73 axle, General 17" on/off road
2008 Lund 1825 Explorer Sport,115 Merc,9.9 kicker,Torklift Super Hitch,42" Supertruss
USAF ret E-9&E-7
campn4walleye
Central WI
Smax, what a great tip! I'll try that! I hate using good water to flush the black tank.
coolmom42
Middle Tennessee
I use a paper towel to wipe food residue out before washing. Then the paper towels go out with the trash. Don't obsess about it, be be more careful than at home. No need to add more potentially smelly stuff than needed.
And of course no grease, just like at home.
2006 Toyota Sienna
Single empty-nester in Middle TN
Jack_Diane_Freedom
Milton Ontario Canada
If we are cooking bacon or something else greasy in the TT (rather than outside) we use paper towels to soak up and absorb the grease and put it in the garbage. Remaining grease get washed with the dishes.
LarryJM
NoVa
ktmrfs wrote: we have one of the small wire strainers in the sink drain opening to catch small food particles, and don't dump grease down the drain. Other than that, everything that can go in the sink ends up in the drain.
DW usually scrapes of dishes with one of the silcone scrapers before washing, but that's more to make dishwashing easier than anything else.
We also use the screen to keep larger scaps of food out of the tank and don't put grease or drippings from frying anything down the drain. We do a light deglaze on drippings and then use a paper towel to get the majority out of the pan. Grease goes into a jar that is kept under the sink and throw out with the regular trash when about full.
Larry
ALL TRAILER MODS>>ETERNABOND INSTALL>>RAINKAP INSTALL
bukhrn
Lanexa, Va
campn4walleye wrote: Smax, what a great tip! I'll try that! I hate using good water to flush the black tank. We always do this when dry camping, as the grey tank will always fill faster than the black.
2007 Forester 2941DS
2005 KIA Spectra
Ron3rd
Upland, CA USA
Sandia Man wrote: We attempt to limit the amount of grease and food particles that goes down the drain but we don't obsess over it either. There are products available for cleaning your grey tanks if grease build-up ever becomes an issue. Happy Camping!!!
That's really all you need to know.
2004 Aljo 250LT
Eaz-Lift WD Hitch
Single Friction Sway Control
Prodigy Brake Controller
Honda EU2000
FunnyCamper
Southeastern
korbe wrote: We normally will wipe our plates with used napkins prior to washing. We will also wipe down everything else with food particles prior to washing. No reason to put that stuff down into the tank and it doesn't take much time at all.
X2
we also are just careful what goes down the drain
Opie431
Bellevue, MI
Any water we use to wash in the sink goes down the drain but my husband usually does the dishes and he does dishes on the picnic table unless it is cold or raining. That water does not go down the drain.
