RV.Net Open Roads Forum: wireless remote control help
 > wireless remote control help
bigdaddy51200
Alabama
Posted: 04/12/12 11:01am Link  |  Quote  |  Print  |  Notify Moderator
I would like to know if a control system is out there that I could control the slides,landing gear, and awning with 1 remote ? I have a 2011 forest river 356RL 5ver with lippert frame (no bashing , no problems here so far)
Thanks for your help,
Bigdaddy51200
2011 Sierra 356RL
2004 Dodge Ram 3500 Larmie DRW 5.9L Cummins Diesel
chuggs
Posted: 04/12/12 11:11am Link  |  Quote  |  Print  |  Notify Moderator
Like this?
bigdaddy51200
Alabama
Posted: 04/12/12 11:21am Link  |  Quote  |  Print  |  Notify Moderator
I was thinking of something like this obile-convenience&Itemid=148">clicky but where can it be purchased? How to install it ?
chuggs
Posted: 04/12/12 11:40am Link  |  Quote  |  Print  |  Notify Moderator
An email to Lippert would get you a list of suppliers...
The instruction manual would show the acceptable wiring choices... It appears they all have a centrally located wireless receiver...which requires 12v... From there you are basically adding wires from the manual switches that you already have...which will continue to work... These wires go to the wireless receiver to act as a pseudo switch...controlled by your wireless transmitting unit.
It's just a fancy switch....
chuggs
Posted: 04/12/12 11:54am Link  |  Quote  |  Print  |  Notify Moderator
Looks like the 2013 Heartland Bighorns come with LINC. You might find a Heartland dealer near you...and they could order/install it for you.
I'm sure they will become available...they're probably just so new...there aren't many online listings for them yet.
the_armadillo
SE Texas
Posted: 04/12/12 01:01pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks guys!!! Something else that I don't need but now want.... Just think of the possibilities.
CincyGus
Cincinnati
Posted: 04/12/12 01:24pm Link  |  Quote  |  Print  |  Notify Moderator
Many programmable TV remotes might be able to work with slide outs. Need to check if it needs an RF or IR signal. Might be handy for those of you that have outdoor TV's to have everything on one remote. One I have at home works with ceiling fans, floor fans, space heaters, cable and sat boxes, dvd/blueray players, Xbox, etc.
Easier to keep up with one remote that does it all than a bunch of small ones. Just a thought.
2011 Silverado Crewcab 4x4
2012 Passport 238ML
Hope your travels are safe and the friendships made camping are lasting.
jbeletti
Crossville, TN
Posted: 04/14/12 05:01pm Link  |  Quote  |  Print  |  Notify Moderator
Below is what I've learned about the Lippert Linc remote control system.
There's a panel of relays (in my case), mounted in a space behind my primary switch control panel in the kitchen area. That panel has a short wire antenna hanging from it. I assume the RF receiver is built into this panel too. Since the relay panel is within a foot of the back of all the manual switches, it's pretty convenient to feed a contact closure from the relays to the switches.
To my knowledge, the system is not sold as a retro-fit, but as someone already pointed out, it's likely to come at some point.
I really like the ability to raise/lower my front jacks while in the truck during the hitching process. Not sure I'll use the step light or awning control features. I have used the slide room feature when running the ODS slides out while standing on that side to ensure I would miss the power pedestal and trees.
Jim
This is from pulling my switch control panel apart to move some light switches.
Jim & Nancy (Ruby & Emme)
2013 Heartland Landmark Key Largo
2012 Ford F450 / Classy Chassis Hauler Bed
bigdaddy51200
Alabama
Posted: 04/14/12 06:28pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the info !! I have to have this
dmandlm
CT
Posted: 03/28/13 04:55pm Link  |  Quote  |  Print  |  Notify Moderator
Jim
