RV.Net Open Roads Forum: Travel Trailers: Need help with new tires
 > Need help with new tires
stellas_keeper
Saint Charles, IL
Posted: 04/12/12 11:24am Link  |  Print  |  Notify Moderator
I have a Jacyo 29A with tires ST 185/80/D13. I need to replace them. I want to get a higher quality tire. What are the sugestions....
Thank you!
the bear II
Torrance CA.
Posted: 04/12/12 11:37am Link  |  Print  |  Notify Moderator
I did research before buying tires for my 5th wheel. I've had problems in the past even with name brand tires. Time and time again in my research it seemed the preferred tire is the Michelin XPS Rib. The RVers had nothing but good things to say about the tires.
I bought a set and only have about 400 miles on them during the past year, I'm satisfied with them so far.
I've always used LT tires on my TT and now on my 5th wheel.
fla-gypsy
North Florida
Posted: 04/12/12 01:32pm Link  |  Print  |  Notify Moderator
Look into the Maxxis tires in your size and weight range. Many of us are very happy with them.
downtheroad
Pacific Northwest
Posted: 04/12/12 11:57am Link  |  Print  |  Notify Moderator
I don't think you can get LT tires in a 13 (185/80/D13).
Many here on the Forum have had good service from Maxxis ST (trailer) tires which are available in your size..
If you want LT tires you will need to also buy new larger wheels/rims and then there may be a clearance issue.
GMC Duramax LBZ
Komfort
Reese Dual Cam HP
Our Rig Picture...CLICK HERE
JIMNLIN
out here
Posted: 04/12/12 02:42pm Link  |  Print  |  Notify Moderator
Your ST185/80D-13 is a bis ply tire. I would go with a radial.
Another good tire for a trailer is the Kumho 857 and is advertized for commercial use. They come in a 185R/13 D load range with a 65 psi rating. Your wheel will need to be 65 psi pressure rated also.
'97 Park Avanue 28' 5er 11200 gvwr two slides
marcus6701
Central PA
Posted: 04/12/12 05:29pm Link  |  Print  |  Notify Moderator
Whats wrong with bias ply tires that make people not want them. Radials have softer sidewalls than bias and will let the trailer sway more. Thats why they have bias on them.
2008 30ft Aerolite, white interior, 2003 Suburban 6.0L 3.73 gears
JIMNLIN
out here
Posted: 04/12/12 06:09pm Link  |  Print  |  Notify Moderator
Radials run much cooler/less rolling resistance at hiway speeds and track the tow vehicle with radials much better than the old bias ply tech tire.
As far as a radial tires having a softer sidewall that may or may not be true. A proper load range/load capacity radial tire has no trailer sway.
Gene&Ginny
North Kingstown, RI
Posted: 04/12/12 06:37pm Link  |  Print  |  Notify Moderator
marcus6701 wrote:
.. Radials have softer sidewalls than bias and will let the trailer sway more.....
I would like to see the source of that info.
Many years ago I remember a friend putting bias ply on the rear of a car that had radial on the front. He wondered why the back end of the car wandered all over the road. He was told that the bias ply sidewalls were softer than radials.
I also recomend Maxxis.
Gene and DW Ginny
2008 Toyota 4Runner 4.7L V8 w/factory towing option
2002 Sunline Solaris Lite T2363
Reese Dual Cam Straight Line HP Sway Control
Proud member of the Sunline Club
marcus6701
Central PA
Posted: 04/12/12 07:02pm Link  |  Print  |  Notify Moderator
I ran a tire shop at a construction company. Everything from wheel barrow tires to 35 ton pay haulers. 988 CAT loader. Any kind of construction equipment you can think of, I've probably changed one at one point. We ran bias ply on things that took side loads due to the stiffness of the tire to support it. Bias ply on the rear of the car will make it loose because the whole tire will flex, radials will flex the side wall leaving most of the tread on the road. I don't go fast enough with my TT to need ALL the traction that the tire provides. If I did I'd be in trouble. I take it easy and stay under 65 mph. Most tire manufactures reccomend inflating 5 psi under the tires rating.
Huntindog
phoenix arizona USA
Posted: 04/12/12 07:08pm Link  |  Print  |  Notify Moderator
The reason for the wandering was tread squirm. Radials have steel belts that prevent it. Bias ply construction actually enables it.
To the OP. 13" tires severely limit your choices. If at all possible, I would bite the bullet now and put the largest possible rims and tires on it. 14" will be better, at 15" you will have even more options.... 16" is the best, but I doubt they would fit.
Here's a tip fo future TT purchases. Buy one that has 6 lug rims. They almost always have 15" rims/tires on them but,,,, 16" will bolt right up making a upgrade to the best easy.
Huntindog
2010 Palomino Sabre 30BHDS
TWO bathrooms...No waiting!
MICHELIN XPS RIBS LRE
2011 Silverado Big Dually 3500 4x4 CC D/A
EQUALIZER Hitch
100% BOONDOCKING
Check out Rusty and her pups at www.bluecollarbrittanys.com
