RV.Net Open Roads Forum: Tell me what truck the Duramax and Allison are teamed up in
 > Tell me what truck the Duramax and Allison are teamed up in
kaydeejay
SE Michigan, USA
Posted: 04/12/12 02:34pm Link  |  Print  |  Notify Moderator
JoeChiOhki wrote:
I'd go with the tried and true Ford 7.3, some of the earlier Dmaxes had some rather expensive injector issues.
Up to 2004.5 with the LB7 engine that is true.
Note the recommendations were for the 2006 to 2007.5 model years with the LBZ engine.
BUT my neighbor has a 2004 and he told me he has a letter from GM warrantying his injectors indefinitely. He has had one replacement set.
Keith J.
1999 Sunnybrook 27RKFS Fiver.
2005 GMC Sierra 2500HD CC/SB/DA 2WD, LBZ air cleaner, 52 gal Titan tank, Bilsteins, Line-X, Westin steps, Prodigy, Retrax cover, 16K Superglide, 5th-Airborne pin-box, Multi-vex mirrors, TST TPMS.
kaydeejay
SE Michigan, USA
Posted: 04/12/12 02:36pm Link  |  Print  |  Notify Moderator
Lots of Stuff wrote:
The Duramax Allison combo is great.
Check the tail pipe when the truck is idling there should be NO noticeable smoke.
Smoking at idle is an indication of very expensive injector problems with a Duramax.
Guess how I know that!!!
Was yours not covered under the injector warranty?
ticki2
NH
I sure would like to see a copy of that letter .
'68 Avion C-11
'02 GMC DRW D/A
woodhog
NS
Posted: 04/12/12 03:25pm Link  |  Print  |  Notify Moderator
Don't get all carried away with the transmission and engine only.
GM has made major changes to the chassis also, frame changes etc.
They have the superior overall truck at the moment with their new models, good GVWR for truck campers now.
2004.5 Dodge 4x4 SRW Diesel, 245/70R19.5 Michelin XDS2, Bilstein Shocks
Torklift Stable loads, BD Steering Stabilizer Bar, Superchips "TOW" Programed,Rickson 19.5 wheels
2006 8.5 Northstar Arrow Longbox 200 Watts Solar, LED lights.
12 Volt DC Fridge.
rfuerst911sc
Marietta Georgia
Posted: 04/12/12 03:40pm Link  |  Print  |  Notify Moderator
In December I purchased a 2001 GMC 3500 DRW extended cab 4x4 with 134,000 miles on it. She runs like a bear and is quite comfortable to ride in. It laughs at the 2500-2600 lb. dry weight of my Avion camper. The transmission is very smooth and I hear the 6 speed auto trans are even nicer. I couldn't pass on the truck because I thought it was a great price. Good luck in your search.
Lots of Stuff
WA. USA
Posted: 04/12/12 04:15pm Link  |  Print  |  Notify Moderator
No! The Extended GM injector warranty is for 200,000 miles or 7 years mine had only 155,000 miles but is 9 years old.
Repair cost was just under $4,700.
DG
03 Chevy Silverado Regular Cab 2500HD 4X4 Duramax
04 Lance Lite 915
Lots of Stuff
WA. USA
Posted: 04/12/12 04:18pm Link  |  Print  |  Notify Moderator
Double post.
MN Ben
Minnesota
Posted: 04/12/12 05:20pm Link  |  Print  |  Notify Moderator
kaydeejay wrote:
I echo the 2006 to 2007.5 truck with the LBZ engine as being the best out there unless you are considering new.
No, I would not consider new.
MN Ben
2002 F250 7.3 PSD
2000 Lance 1010
MN Ben
Minnesota
Posted: 04/12/12 08:44pm Link  |  Print  |  Notify Moderator
Follow up question....
What are the trim levels of the GMC/Chevy truck. I am partial to the XLT of the F150 and the Ranger but I am not familure with GM. I am just wondering what the low, mid, and top grades are refered as.
btw, thanks for the info on the duramax.
MN Ben
Bigfootchevy
Bancroft, Ontario, Canada
Posted: 04/12/12 09:00pm Link  |  Print  |  Notify Moderator
The Duramax Allison combo is great ad I have had 3 diesel truck to prove it. Buy the GM you will be happy you did. Both Ford and Chrysler make great trucks also.
Paul
