RV.Net Open Roads Forum: What do I look for when buying an RV?
 > What do I look for when buying an RV?
RayChez
Barstow, Ca. USA
Posted: 04/12/12 05:15pm Link  |  Print  |  Notify Moderator
I have had both gas and diesel and for me diesel is superior to gasoline engines. Diesel engines have more torque and last three time more then a gasoline engine before they need over haul. The diesel coach is a heavier coach so cross winds do not bother them like gasoline coaches. The longer the diesel coach the better it handles. Once they go over 42 feet long they are required to have a tag axle which gives them a higher carry capacity. Also handles even better on cross winds. Gasoline motorhomes will cost less then diesel and there are some nice gasoline motorhomes, but test drive both and you will see the difference. No spark plugs to change on a diesel, but they do use a lot more oil in the sump then gasoline engines, But a gasoline engine you need to change the oil more frequent. Six thousand vs sixteen thousand for a diesel. Since a diesel coach is bigger, tires are bigger and cost more. But I would never go back to a gasoline coach. Love my diesel pusher.
2002 Gulf Stream Scenic Cruiser
330 HP Caterpillar
3000 Allison Transmission
Neway Freightliner chassis
2013 Honda CR-V EX
Aventa II
FMCA member
Ivylog
Blairsville, Ga. USA
Posted: 04/12/12 05:24pm Link  |  Print  |  Notify Moderator
Welcome to the forums. More info would be helpful,,, like what's your budget, are you handy, have your RVed before, how many days/year are you going to use, how many miles do you plan on traveling/year???? Stay away from Alfa's and buy more MH than you think you need ONE TIME!
04 Monaco Dynasty 42' quad slide
Where am I?
How I tow.
Dale.Traveling
Newport News, VA
Posted: 04/12/12 05:34pm Link  |  Print  |  Notify Moderator
Sarge34 wrote:
Thanks again everyone. Now gas or diesel?
Depends on travel plans and budget. Lots of on the road time - diesel. Weekends close to home and a summer vacation - gas. If your budget will support a diesel then by all means a diesel.
2006 Hurricane 31D aka 'Moby' the Whale
FCC(SW) US Navy Retired 1980-2003
Stella my Navigator
Bogart the All American RV Dog
and
Cocoui waiting for me at the Rainbow Bridge
Captain_Happy
Abilene, Texas
Posted: 04/13/12 04:23am Link  |  Print  |  Notify Moderator
Gas or Diesel, How deep are your pockets? Diesel engines cost more, cost more to servive, diesel fuel is higher, and if major things go wrong with the engine, you wished you never owned it. And those 22.5 tires cost more too. if you've got the cash, go for it.
bsinmich
Holland, MI
Posted: 04/13/12 05:17am Link  |  Print  |  Notify Moderator
We average around 5000 miles per year. This is the perfect amount for the annual oil change/lube on the gas engine. I get a Mobil 1 oil change at Wal-Mart for around $60. and the same mechanic always works on it for the past 6 years. A diesel pusher will go 10-20K milees between oil changes and cost much more than that. They can take up to 40 qt. of oil and have 3 filters to change. That doesn't happen on $60. Your use will make a huge difference in your choice. We use the toad to do a lot of sightseeing once we get parked and the RV is simplyour motel. We are in a LaQuinta today for 2 nights and I already miss the MH and my own bed but this time it worked to not use the MH.
2003 Newmar Mountain Aire, Workhorse W22, 2008 Saturn Vue, Falcon 5250, & US Gear Unified Tow Brake
paulcardoza
Southeastern Massachusetts
Posted: 04/13/12 05:29am Link  |  Print  |  Notify Moderator
Sarge --- Giving us some idea of your budget for a rig would help us advise you.......
Paul & Sandra
New Bedford, MA
2003 Monaco Executive M43 DS2
Wills250psd
walnutcove NC
Posted: 04/13/12 05:33am Link  |  Print  |  Notify Moderator
No matter what kind of RV check fo leaks,leaks,leaks past and present in the roof,walls,floor, storage underneath,inside cabinets and closets.
horizon36
Henderson, NV
Posted: 04/13/12 08:50am Link  |  Print  |  Notify Moderator
Based on your first post I'm guessing that you are close to retirement or already there. If that's the case and you will be traveling extensively and living in your rig for an extended period of time I would recommend a DP. Buy the biggest you can afford so you only have to buy one time.
Live Long and Prosper.
Home is where we park it.
FT since August 2010
'02 Itasca Horizon 36LD
'02 Jeep GC toad
nbargolf
St Augustine
Posted: 04/13/12 09:01am Link  |  Print  |  Notify Moderator
IMHO fiberglass roof much less problems. Gas is my choice had a diesel and the maintenance cost and fuel is way higher. We would rather put the money into traveling. My gasser does everything I want.
Mr.Mark
California/Tennessee
Posted: 04/13/12 09:23am Link  |  Print  |  Notify Moderator
After 7 years of research before we decided to buy (we rented 3 units, a class-C and 2 class-A's), I always heard buy your THIRD motorhome first. So, I feel that's what we did. At 5 yrs of ownership, we're happy and we think we got everything we wanted since we special ordered the coach.
MM.
Mr.Mark
2008 Monaco Dynasty, 42.2 ft., 4 slides, 425 hp clean-air Cummins diesel
2013 Honda CR-V EXL, AWD, w/Nav, SMI Air Force One vacuum-assisted braking
