RV.Net Open Roads Forum: Problem with 303 Aerospace leaving streaks after getting wet
 > Problem with 303 Aerospace leaving streaks after getting wet
dennysbabe
La Quinta, CA.
Posted: 04/12/12 03:38pm Link  |  Print  |  Notify Moderator
Has anyone had a problem using 303 Aerospace for waxing the sides of their RV? We applied it on our 2008 Cameo after reading about people recommending it but it's not adhereing to the sides. Apparently the sides are a different product from the end caps because the fiberglass end caps are okay. Any suggestions for what wax to use on the sides?
HappyKayakers
Black River Falls WI
Posted: 04/12/12 04:31pm Link  |  Print  |  Notify Moderator
I just bought some more 303 and noticed something I didn't remember in the directions- to wipe completely dry. This would usually entail several rags/towels. I emailed the company to find out what would happen if I didn't completely dry after applying. I got a list of several possible consequences and streaking was one of those.
Joe and Dakota, the wacko cat
2006 Dodge 3500 QC CTD SRW Jacobs Exhaust brake
2006 Heartland Bighorn 3600RL, MorRyde suspension, TrailAir pinbox
http://happykayakers.com/blogger/
Twomed
FL winters and then somewhere cool
Posted: 04/12/12 04:34pm Link  |  Print  |  Notify Moderator
You used too much, or didn't wipe it down dry enough as mentioned. A little goes a looooong way, and practice makes perfect as with any product.
Happy Trails
06 Monaco Dynasty
07 Hummer H3
FMCA 279843
harold1946
Surprise Arizona
Posted: 04/12/12 04:49pm Link  |  Print  |  Notify Moderator
303 is not a wax and should not be applied as such. The most common issue is using to much. Two squirts on a rag and spread it, then buff untill completely dry.
Harold and Linda
2009 CT Coachworks siena 35V
W-22 Workhorse 8.1L
Explorer toad
pulsar
Lewisville, NC
Posted: 04/12/12 05:52pm Link  |  Print  |  Notify Moderator
Moved from Forum Technical Support.
Veebyes
Bermuda & Maryland
Posted: 04/13/12 06:35am Link  |  Print  |  Notify Moderator
I would never consider using 303 as a replacement for a good waxing with a marine grade wax or sealant. Easy? Yes. Quick gratification? Yes, but it won't last long. A high grade pure wax/sealant, not a cleaner wax, will last a year for the sides & back. If you are a high milage traveler the front cap, bugs, will need twice a year.
303 is an excellent replacement for anything one would otherwise use Armour All on.
2007 Alpenlite 34RLR
ArticFox 676
West Melbourne, Florida
Posted: 04/14/12 06:05pm Link  |  Print  |  Notify Moderator
We only use 303 on our awning and other vinyl. Fiberglass gets marine wax for longer lasting.
