RV.Net Open Roads Forum: Travel Trailers: Friction sway control question
 > Friction sway control question
BossCamper
Southwestern Ontario, Canada
Posted: 04/12/12 03:56pm Link  |  Print  |  Notify Moderator
I am going to put a second sway control bar on our rig.
My question is :
Can I mix brands, or should I get two new ones so they match. (I mean in function ... NOT appearance )
I can't find the same make as the one I have now. I find different brands, that look the same, but do they all grab the same?
And how particular do I have to be in setting the drag the same on each?
Experience is that which you gain immediately after you actually needed it.
2011 28' Kingsport 28RLS by Gulfstream
2010 Ford F150 Supercrew
rgolding
Southern Illinois
Posted: 04/12/12 04:22pm Link  |  Print  |  Notify Moderator
I don't think swaying to one side equals swaying to the other. I've hauled a cargo trailer with two on it and they worked together.
LBL 1206
Land Between the Lakes, TN
Posted: 04/12/12 04:46pm Link  |  Print  |  Notify Moderator
Except for one manufacturer/model I looked at, I think they are all
made at the same shop and each company puts their own label sticker on it....
Terryallan
Foothills NC
Posted: 04/12/12 05:47pm Link  |  Print  |  Notify Moderator
All the same. put it on Tighten down the on/off lever, and good to go.
Terry & Shay
Coachman Apex 288BH.
04 F150, 5.4, Lariat SuperCab
Lazy Campers
BossCamper
Posted: 04/12/12 05:50pm Link  |  Print  |  Notify Moderator
Thanks for the replies. I sometimes tend to over think things a bit.
If I could afford it, I'd get a Hensley, or Pro Pride.
Ah well ... sigh....!
LarryJM
NoVa
Posted: 04/12/12 06:07pm Link  |  Print  |  Notify Moderator
That's a fairly absolute "GENERAL STATEMENT" w/o any supporting information. I think I will pass on your post for accuracy at this time.
To the OP I would try and mix and match and see how it works. If you are unsatisfied then upgrade the older one to the same brand as the new one.
Larry
ALL TRAILER MODS>>ETERNABOND INSTALL>>RAINKAP INSTALL
CopanoCruisin
The Great State of Texas
Posted: 04/12/12 07:06pm Link  |  Print  |  Notify Moderator
We have a valley brand on one side and a bullydog brand on the other. Open Range Jt337 RLS., pulled with a 2010 F150 SC. The trailer nor the truck know that they are different brands, works great !
tmprkswyo
Southwest Wyoming
Posted: 04/12/12 07:43pm Link  |  Print  |  Notify Moderator
I canot be convinced that mixing brands would be an issue. Even if you had two of the same brand there would be no way you could determine that the two were equally adjusted to the exact same friction. I wouldn't worry about it.
jerem0621
Sequatchie, TN
Posted: 04/12/12 08:03pm Link  |  Print  |  Notify Moderator
I second what the others are saying.
Just buy another bar and add it to the TT.
Before I went to a more advanced form of sway control I ran two friction bars, they worked pretty good.
I decided not to pay the $20.00 premium to get a "left side" or "drivers side" sway bar.
I just bought a standard sway bar for the passenger side. Took the slide out, unscrewed the "adjustment screw" and flipped the slider bar, adjustment plate, adjustment screw and the on off handle upside down. Saved myself $20.00 and took about 60 seconds to turn my right hand bar to a left hand bar.
Your second bar will take a little of the extra "wiggle" out of the TT, but it will not be a night and day difference.
I went through the progression as well
1) get the hitch set up right- still had a lot of "suck and pull" from passing vehicles
2) Add first friction sway bar- NIGHT and DAY difference, a lot of the "suck and pull" was gone but not all, not even close.
3) Add second friction sway bar- better, very stable, didn't feel like I was fighting when a semi passed.
Now for me I have a number 4)
I bought my add on dual-cam sway control on eBay used and very cheap.
It took some work, but now it is dialed in, all extra "wiggle" is gone, passing vehicles still push, but they push the entire rig, not just the trailer. Vehicle control is simply exceptional with Dual Cam.
I seriously doubt I will ever upgrade to a Hensley or a ProPride, I just don't see the need.
Dual Friction bars will probably work very well for you, they did for me.
Thanks!
Jeremiah
TT: 1995 Layton 2910
Tow Vehicle: 1999 F-350, v10, 2wd, Crew Cab, Dually
Hitch: Draw-Tite Trunnion WD Hitch
Sway Control: Valley dual friction sway control
Brake Control: Tekonsha Voyager
"It's Kind of Fun To Do The Impossible"
~Walt Disney~
wmoses
Houston, Texas, USA
Posted: 04/12/12 09:29pm Link  |  Print  |  Notify Moderator
My question is :
In my opinion you can mix and match no problem. The effect is additive since the entire assembly they are attached to is rigid and does not flex. Because of that you also need not worry about equalizing the friction effect between the two. If this were not true then any asymmetric setup (read one-sided, single friction bar) setup would be a problem.
Regards,
Wayne
2010 Jayco Jayfeather EX-Port 17Z | Tekonsha Prodigy P3 brake controller
2010 GMC Sierra 1500 SLE 5.3L Vortec V8 6-speed with Power Pack Plus Package | Hypertech Max Energy tune
_
