RV.Net Open Roads Forum: Fifth-Wheels: Shower Faucet Spray....
 > Shower Faucet Spray....
sloman2001
Bristol, IL
Posted: 04/12/12 04:14pm Link  |  Print  |  Notify Moderator
Fairly new to RVing, and now have our first fifth wheel. My question, do all of you experience low water pressure in your shower such that it has a small spray, but also quite a bit of dripping from the shower head as well? I don't expect the spray I get at home, but I also expected a bit more than what I have. Are the shower sprays in most campers kind of crummy, or should I suspect a problem or is there a secret solution? The other oddity, I use the small sliding shut off valve near the top of the shower head when lathering up to conserve water, but when I slide it back into position to resume the water spray, it is always cold and never the same tempertutre it was when I turned it off. Can anyone shed any light on any of this?
past-MIdirector
Michigan
Posted: 04/12/12 04:25pm Link  |  Print  |  Notify Moderator
Get an Oxygenics shower sprayer and will take care of your problem.
donhov
near Jackson Michigan
Posted: 04/12/12 04:30pm Link  |  Print  |  Notify Moderator
If you do not want to change the head, just remove it and look either at the faucet end or shower head end enlarge the hole in the washer inside. It is a flow reducer and that should help.
2003 Cedar Creek 30RLBS
2007 Dodge 5.9 Cummins Turbo Diesel 325hp/610Tq
4x4 3.73 axles short bed
Inferno Red W/Gold pinstripping
skylos
Columbus, OH
Posted: 04/12/12 04:32pm Link  |  Print  |  Notify Moderator
Are you running on the onboard water pump, or are you using the pressure from the city water connection?
Cross-connecting the water sides (having both valves open to the same water chamber behind your cutoff) is always perilous without backflow preventers - due to plumbing resistance differences between hot and cold and other such unobvious reasons, the cold water can go down the hot pipe or vice versa, thus when you reopen the cutoff valve, you get the water from both pipes again - which may actually effectively be the water from one pipe, briefly.
I think I've rambled on confusingly enough.
cabanaman
florida
Posted: 04/12/12 04:34pm Link  |  Print  |  Notify Moderator
The oxygenics showerhead from camping world has been great for us for 6 years now.Plenty of power in the lowest pressures.
Retired Navy
2007 Dodge Ram 2500 quad cab 6.7 cummins,6 speed auto,exhaust brake.
2007 Open Road 378SA4S-5,equa-flex and morryde X factor,wet bolt kit,michelin ltx M/S 2 tires
http://www.gofundme.com/Carebear (my daughter)
tvman44
Southwest Louisiana
Posted: 04/12/12 04:35pm Link  |  Print  |  Notify Moderator
Oxygenics is the way to go, we have 2 one in the 5er and one in the S&B.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
sloman2001
Bristol, IL
Posted: 04/12/12 04:40pm Link  |  Print  |  Notify Moderator
We are connected to the water sources at the camping sites, we have yet to use the fresh water tank and pump.
Thanks for the info on the alternate shower spray available, and the idea of expanding the washer. Also thnaks for the explanation about the cross connection on the water supplies, it all makes so much sense now.
Thanks again, Tom
travel4family
Ohio
Posted: 04/12/12 05:01pm Link  |  Print  |  Notify Moderator
Good tips, we've wondered in our new TT, too. We'll probably add it to our wish list.
Amazon is $5 cheaper than CW, today at least. And with the free shipping, it's closer to $10.
Jim Cindy
Northcentral, PA
Posted: 04/12/12 05:06pm Link  |  Print  |  Notify Moderator
Another vote for the Oxygenics. You will be amazed.
PBH Portable Beach House
2008 GMC 2500HD Duramax Allison
2009 Cameo 34CK3
MorRyde IS, Disc Brakes, G614's
PullRite Super Glide Hitch
Propane fueled Yamaha EF 2400is
salem
Central Valley, Ca
Posted: 04/12/12 05:21pm Link  |  Print  |  Notify Moderator
Looking at the Amazon website I see that they have several types of Oxygenics shower heads. Which type are you RV'ers using, or does it matter? Thanks
