I have an Onan 7500 diesel generator and would like to do my own servicing. Oil, filter,fuel and air filter. Where can you get the items needed to do this.....auto parts store, online? Want to be sure to get the right oil and filters the first time as I havent done the servicing myself yet! Thanks for any suggestions.......
Local auto parts, online, or your local Cummins dealer should all have or can get what you need. Just get the numbers off your existing filters and they can cross them over if they don't have that brand. I would have them compare those numbers to what the book calls for to verify that the current part numbers are correct. For oil, check your owners manual. If it doesn't say, then I'd personally use Rotella or Delo 400 in a 15W40 weight.
Hope that helps.
'93 Jayco FS3500 TT behind a '92 Dodge D250 powered by 5.9L Cummins
'94 Vogue Prima Vista powered by 8.3L Cummins w/ 6spd Allison
I took my old filter in with me to Napa and bought one that was about an 1" longer. Checked door clearance first. Did that because the short one Onan specs is difficult to get in & out..even with the special wrench they sell for it.
Found out had to move Exhaust pipe to get at fuel filter on mine. 7500 Onan.
2002 Fleetwood Discovery
330 cat. '09 Escape toad.
Kathy & Joe wish you well.
My mind works like lightning,
one brilliant flash and it's
gone. (Maxine)
