GWnKIDS
Riverside
We have narrowed the choices down to the Monaco DFT the question is what beneficial is the tag axle? The non tag is a 40' so we loose 1 sink in the rear bathroom over the 43' (well its over 44'). We are coming out of a 5th wheel and just want to make the right decision. with the ride quality being very important. The cost difference is only $ 20,000 so that is not an issue.
Which will have a better hwy ride?
Thanks
Ka Ron
Kelowna
We have a tag axle on our 36' and it allows for more weight and a more stable ride.
We have a gas unit though.
Join Us For A Trip Down The RV Highway
steveownby
Cosby, TN
The Monaco tag axle coach with 10 air bags and 10 shocks is extremely stable over the road. The tag also gives you a good bit more NCC/CCC capacity and the ability to transfer some weight from the drive axle to the steer and tag axles to fine tune the balance.
Steve Ownby
2003 Monaco Signature
Full-time since 2007
Ivylog
Blairsville, Ga. USA
I usually ask, what kind of car do you drive? If it's a Town Car then a non tag might do BUT if you drive a car that loves curvy roads, then you want a tag. Also, 40' non tag axle DPs have very little CCC while tag's will have 7000+.
Once you've owned a DP with a tag axle you will NEVER go back to a non tag. The 10 airbag Monaco's give rock solid handling and 13 hour days are a pleasure. Spend the extra $20K and do it right the first time... NOT like me that started with a 36' DP and then a 40' and now a 42'. Do not worry about finding USFS, BLM, SP, NP, or COE sites big enough, just dont try on Friday afternoon. BUY MORE DP THAN YOU THINK YOU NEED... ONE TIME, not like me.
04 Monaco Dynasty 42' quad slide
Where am I?
How I tow.
Mr.Mark
California/Tennessee
Another small benefit with the tag is that you have an extra set of tires to rotate to the front. We did exactly that. Our tag tires looked barely used as the front were showing a little wear. So, I had the tag tires rotated to the front to have a 'fresher' steering tire.
I think the tag axle gives a better ride. It eliminates porpoising and makes the coach drive straighter and no issues with trucks passing or heavy winds.
MM.
Mr.Mark
2008 Monaco Dynasty, 42.2 ft., 4 slides, 425 hp clean-air Cummins diesel
2013 Honda CR-V EXL, AWD, w/Nav, SMI Air Force One vacuum-assisted braking
CA Traveler
The Western States
Tag axles give the better ride. Both the tag and the extra weight contirbute to the ride. The tag does consume outside storage space but then the rig is usually longer with more inside and outside space.
By extra weight I mean as the rig exceeds 20K lbs/axle extra tires are required.
More tires, brakes and $ for purchase and maintenance.
2009 Holiday Rambler 42 Scepter with ISL 400 Cummins
2004 Honda CR-V
Bob
Gsmitty77
San Diego
Tag it baby!!!
Smitty
http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/25720428/gotomsg/25721486.cfm#25721486
ole trucker
Florida.
If your budget allows it , there are no cons!
Will's '00 Endeavor
38wdd,01 2500HD
LIVALIL
Oh,I used to be disgusted, but now I try to be amused-
Elvis Costello
Executive
I agree with two of the posters above....there are no cons and once you have one you'll never go back. If you haven't driven either coach, I would suggest you do so before you purchase. Do it on a very windy day and you'll see what we are talking about...the ride is what its about...how many TOUR busses do you see without a tag..>?????....Dennis
Dennis and Debi
Chevy HHR W/ ReadyBrute
Fourth Year Full Timing Click here to view our travel blog
gbopp
The Keystone State
Gsmitty77 wrote: Tag it baby!!!
Smitty
Clicky
