Majikal-Joe
South Jersey
Anyone have some knowledge on how to replace those front air bags on a 1996 P-30 chassis. I don't see anywhere in the Chilton Manual #28642 for 87 to 97 GM's. And a outlet that sell them. Thanks for your input.
Joe
Jersey Joe and Marianne with Dale the cat. #3
dmck413
Fluvanna Va
Firestone makes a set that go in through the hole in the bottom.
mike brez
milford ct
They come out through the hole in the lower controll arm. Use a razor knife and vice grips to slice and pull out. Put the new bag in hot water to soften up. Roll it up real tight and use zip ties to hold together. Start to reinstall through the hole in lower controll arm and snip the zip ties as they get to face of controll arm. I just ordered Henderson springs for mine and installing them and ditching the air bags. Spring replacement video
1994 Pace Arrow 33L,454,P30
2oo4 ground up ridgid chopper 120rwhp
http://community.webshots.com/user/oneHD
Sully2
Cincinnati
Buy "AirLift" brand bags...much better quality
Reach in between coils and slice the dead bag to smithereens...and pull the pieces out.
Take the new bag(s) and roll in a long cylinder like a jelly roll and tape them with a few bands of plain old masking tape.
Soap up the new bags well...and insert thru the hole in the bottom of the frame but before you are full installed...slide in the rubber biscuits that come with it ( protects the very top of the air bag)
Reach in and CAREFULLY cut the masking tape and the bags will pop out to fill the spring but still need inflated to the proper PSI.
2000 Country Coach Allure; Cummins ISC 330 HP; 71/2 - 8 MPG regardless
2002 Jeep Liberty
Sully2
Cincinnati
double..please delete....as if I had to ask.
Mnwild
Minnesota
HI JOE, I just did this what a pain, I got a set from amazon for around 80$ . There airlift 1000 pn. 81560 the amazon site says there for the rear but if you go to the airlift site it gives you this part no. for the Chevy P30 P32 front coil springs. They come with instructions. I had to use stainless screw clamps to get them small enough to go thru the 2 inch hole. But I didnt try the hot water trick, do a search for air bags on this site and you will get more instructions. Good Luck. Ken
Majikal-Joe
South Jersey
Ok guys thanks Mike thanks for the video link, MnWild thanks for the part numbers on amazon.
harold1946
Surprise Arizona
Once they are installed be sure to raise the front of the coach so the tires are off the ground and inflate to #100-#110. This allows the bags to fully expand. Then lower the coach and reduce the pressure to the desired level.
That information is not included in the installation instructions.
The Firestone bags have a free replacement warrantee.
Harold and Linda
2009 CT Coachworks siena 35V
W-22 Workhorse 8.1L
Explorer toad
gbopp
The Keystone State
I didn't replace mine yet, I found this info, it should be about the same for any bag.
Air Bag Replacement
tropical36
Southwest Florida_USA
Majikal-Joe wrote: Anyone have some knowledge on how to replace those front air bags on a 1996 P-30 chassis. I don't see anywhere in the Chilton Manual #28642 for 87 to 97 GM's. And a outlet that sell them. Thanks for your input.
Joe
AIR LIFT made a bunch, but not sure if they still do.
Some use a hole saw right up through the bottom to destroy it and then fish out the pieces Running the jacks down with allow the springs to stretch, which may facilitate digging them out. The new ones are wet, soapy and twisted that allow you to feed them through the bottom.
I really don't see this job as cost effective though, with Camping World supplying, installing and guaranteeing them at a very reasonable price.
Now, having said this, I finally learned my lesson and just had them install super steer after market coils and the way to go if you're keeping it.
"We are often so caught up in our destination that we forget to appreciate the journey."
1998 36ft. National Tropi-Cal Model 6350 on a 1997 Chevy P32
Chassis_7.4 Vortec Engine_4L80E Tranny_slide_tag axle.
Dinghy_2010 Jeep Wrangler JKU ISLANDER.
