amazingvanstones
Southern Ontario, Mexico or somewhere in between.
It's time to replace the rubber on our 2006 Monaco Camelot. The coach currently has 295 80R 22.5 Goodyear 670. I have a chance to get a heck of a deal on a couple of 305 70R 22.5 Michelins for the Steers. do I do it? Advantages? Disadvantages?
2006 40' Camelot, 02 Explorer Sport Trac 4x4, Remco Disconnect.
RVquestions.net
AmazingVanstones.com
hershey
Albuquerque,(fulltime) NM, USA
Personally, I'd have no problem with the switch but,as your header indicates: "Tire Experts". I don't know if there is a Tire Expert on the list so I'd check with a Michelin Tire Expert to make that decision. Not just Willie Lump Lump behind the counter, get a phone number from the operation of someone in the field that can give you an accurate professional answer. You have a lot riding on your choice. (no pun intended, but.....)
hershey - albuquerque, nm
Someday Finally Got Here
Superman was an illegal alien.
NASCAR 14 - 99
bluebirdPT36
NE Tn
Ain't no expert. The loaded radius of the 305 is about 1.1 inch less than the 295. Also I assume the 295 is OE on your 2006. The low pro tire may or may not ride rougher. I would stay with the original size. This opinion is worth what you paid for it.
garym114
Bluff Dale, Texas
Are the same load range?
Jarlaxle
New England
Will they fit the wheels, carry the weight, and NOT hit at full steering lock?
John and Elizabeth (Liz), with 3 nutty cats
My beloved St. Bernard, Marm, lost him 1/2/12
Current rig:
1992 International Genesis school bus conversion
Macktee
Canada
hershey wrote: Personally, I'd have no problem with the switch but,as your header indicates: "Tire Experts". I don't know if there is a Tire Expert on the list so I'd check with a Michelin Tire Expert to make that decision. Not just Willie Lump Lump behind the counter, get a phone number from the operation of someone in the field that can give you an accurate professional answer. You have a lot riding on your choice. (no pun intended, but.....)
X2 Be carefull and get proper advise from the experts. Macktee
04 Monaco Dynasty Diamond 1V ( Homer II)
2012 Ram 1500 4X4 Quad Cab towed
2011 Dodge Journey
2013 Cargo Mate 24ft enclosed car hauler
Tom and DW Nancy
Holliday Trails member
Good Sam Life time member
FMCA member# F419937
Ivylog
Blairsville, Ga. USA
What are your front axle weights? I put with 315/80's on the front of my Dynasty so I would not worry about a 305 fitting and you will gain 500lbs of load rating. I'm probably going to replace my rear tires with 11R22.5's instead of 295's as they are not as expensive.
04 Monaco Dynasty 42' quad slide
Where am I?
How I tow.
gbopp
The Keystone State
Check the age of the tires, maybe there's a reason you're getting a heck of a deal.
