RV.Net Open Roads Forum: Tech Issues: Balancing ST tires
 > Balancing ST tires
LarryJM
NoVa
Posted: 04/13/12 06:46am Link  |  Print  |  Notify Moderator
Fish-a-Palooza wrote:
This is a wear issue as well as a safety issue.
That IMO is a complete WAG on your part w/o any substantiated facts to support that WAG.
The geometry of TT tires (usually two within inches of each other) on tandem trailers is vastly different again IMO that tires at the four corners of motorized vehicles such as cars, trucks, and MHs. It would be interesting to see of OTR tractors balance only the steer axle tires.
Larry
ALL TRAILER MODS>>ETERNABOND INSTALL>>RAINKAP INSTALL
Ron3rd
Upland, CA USA
Posted: 04/13/12 06:59am Link  |  Print  |  Notify Moderator
Beach-Rat wrote:
Balancing ST tires.
I always have but dealer says it's a waste of $$$ ...
225/75-R15.. do you balance them or not?
My trailer did not come with balanced tires when purchased new. I've heard this is the case with many new trailers. Whether or not they need to be balanced is a matter of debate and the question pops up here from time to time. Balancing them certainly can't hurt anything and is probably a good idea IMO. America's Tire/Discount Tire always balances every trailer tire they sell as a matter of policy.
2004 Aljo 250LT
Eaz-Lift WD Hitch
Single Friction Sway Control
Prodigy Brake Controller
Honda EU2000
Hamops
Oshawa, ON, CA
Posted: 04/13/12 07:09am Link  |  Print  |  Notify Moderator
Beach-Rat wrote:
Balancing ST tires.
ASOLUTELY!!!!! Balancing your trailer tires, means a smoother riding trailer. That's means an easier pulling trailer which means a slight improvement in fuel mileage.
It surprises me that the tire dealer didn't want to balance the tires. It's money for him.
Cheers
Helen & George VE3INB and Max (Bichon Frise)
2006 Silverado 2500HD D/A, Isspro Gauges, Linex, Westin Nerf Bars, Fold-A-Cover
2006 Cruiser CF30SK.
Reese 16K Slider, Bedsaver, Prodigy Controller, Rearview Camera, JT StrongArms
phillyg
Front Royal, VA
Posted: 04/13/12 07:34am Link  |  Print  |  Notify Moderator
Have you ever seen a car going down the road with a rear wheel hopping up and down. That's what happens when a wheel is badly out of balance. Same thing with trailer tires. I'd gladly pay the small amount of money for balancing.
2002 Keystone Cougar 286, 8,400lbs loaded, pulled with a 2004 F150 Supercrew, 5.4, 3.73 gears. Retired and enjoying life
RCMAN46
NorthWest
Posted: 04/13/12 09:16am Link  |  Print  |  Notify Moderator
If you are having problems with drawers opening when towing your trailer balance the tires and the problem will probably go away. I balance all tires on my truck and trailer. I use balance beads as the drums on most trailers are not balanced and the beads take care of this.
Fish-a-Palooza
Lake Stevens WA
Posted: 04/14/12 02:15am Link  |  Print  |  Notify Moderator
Larry
As soon as I find out what a wag is I can reply. Ok I looked it up. Does it mean Wild a$$ guess? I wasn't aware I needed to submit a resume to state an opinion. I see you have an opinion as well.
FWIW, I was ASE certified on suspension/alignment and brakes and a tire guy in a repair shop for 5 years so I think I'm qualified to express an educated opinion.
The argument for not balancing wheels on trailers is; a comfortable ride is not necessary for a trailer and from that stand point, correct. However, from a wear and towability stand point depending on how bad the tire is out of balance it can make a big difference causing handling issues and tread seperation.
As just one personal example, one of my boat trailers was jittering down the road like crazy as I towed it. I no longer had access to the machines so I took it to the tire shop where I purchased the tires. I actually had to argue with the L** S**** tech about getting them balanced and finally told the tech it was my money, just do it. They used 3 oz of weight to balance one and 2 oz on the other. Once done, the jitter went away.
* This post was last edited 04/14/12 03:15am by Fish-a-Palooza *   View edit history
Wayne & Karen
TT-2005 Komfort 27TSG
TV-2003 F250 Lariat Crew cab, 6.0L PS, FX4
Learjet
Louisiana
Posted: 04/14/12 08:18am Link  |  Print  |  Notify Moderator
I balance my tires, cheap insurance and it can ONLY help.
2013 Ford F250 XLT 2wd Crew Cab 6.2 and 3.73 rear
2006 KZ Frontier 2303P-F
Dual 6 volt GC batts
Equal-i-zer
Yamaha EF2600c Tri-Fuel Gen.
Champion Model 46595- 3000/3500
sold* 2001 Hurricane 30Q Chevy workhorse
sold* 2006 Nissan Titan CC with tow package
09FLSTC
Out West
Posted: 04/14/12 11:49am Link  |  Print  |  Notify Moderator
Best waste of money money can buy!
ol Bombero-JC
Posted: 04/14/12 12:48pm Link  |  Print  |  Notify Moderator
Only if the tire shop uses Chinese weights to balance!.
smkettner
Posted: 04/14/12 01:50pm Link  |  Print  |  Notify Moderator
Probably is a waste if the dealer only does hub centric balance.
Trailers usually need lug centric balancing.
And yes I have mine balanced.
675 watts solar
