RV.Net Open Roads Forum: Tech Issues: Any resistance difference?
 > Any resistance difference?
nvreloader
Western Nevada
Posted: 04/12/12 09:30pm Link  |  Print  |  Notify Moderator
You have 2, size 8 Solar cable/wires, one is 7 strand and the other is 50+ strands,both are copper material, both are identical (except for the strand count), would the resistance be the same for each cable/wire?
2010 F-350,6.4PSD, 6spd man trans,CC,SWB,SRW, Caravan camper shell,50 gal bed tank,17,000lb Husky WD hitch,Northwoods 2008 28KS Desert Fox Toy Hauler,2005 Honda 500 Rubicon ATV w/rumble seat,1 Aussie waiting,watching and ridin shotgun on the whole outfit.
Wayne Dohnal
Bend, OR.
Posted: 04/12/12 09:36pm Link  |  Print  |  Notify Moderator
It should be the same because the wires are supposed to have equal copper cross-sections. There are some differences, however, with different wire types: AWG wire is thicker than SAE wire of the same gauge, and welding wire is generally thicker than non-welding wire. But in the same wire class, any wire of the same gauge is supposed to have the same copper cross section, and therefore the same DC resistance.
2009 Fleetwood Icon 24A
Honda Fit dinghy with US Gear brake system
LinkPro battery monitor - EU2000i generator
MEXICOWANDERER
las peƱas, michoacan, mexico
Posted: 04/12/12 10:25pm Link  |  Print  |  Notify Moderator
Circular Mil, Circular Mil, Circular Mil
In extremely high frequency applications the finer stranding will carry more.
Go with high quality AWG wire with really thick insulation. SEAL THE ENDS with meltable inner liner heat shrink tubing to prevent O2 from migrating into the cable and oxidizing the copper strands.
mena661
Posted: 04/12/12 10:13pm Link  |  Print  |  Notify Moderator
They'll have different current carrying ratings. The 7 strand will carry more.
Trojan L16 6V's 740 Amp-hours
randrx2
Newport News, VA
Posted: 04/13/12 03:10am Link  |  Print  |  Notify Moderator
Yep, the resistance is different, but probably negligible.
As the stranding goes up, the resistance goes up.
The effect is very small, like 0.014 ohms per 1000 ft., but it is there.
This can be measured, but you would need a DLRO (Digital Low Resistance Ohmmeter) to do it. It measures micro-ohms. 1 micro-ohm = 0.000001ohm. Your average test meter in your house is not going to measure that.
Also, there is differences in resistance from different manufacturers of wire. If you know the manufacturer of both pieces, you could probably look up the specs on the wire and find the ohms per 1000ft. rating.
* This post was edited 04/13/12 03:29am by randrx2 *
When someone says, "I'm not book smart, I'm street smart." All I hear is, "I'm not real smart, I'm imaginary smart."
garym114
Bluff Dale, Texas
Posted: 04/13/12 07:39am Link  |  Print  |  Notify Moderator
8 gauge is 8 gauge. Both are AWG and both will have the same 24 amp power transmission rating. If there is a difference it will be very small.
mena661
Posted: 04/13/12 08:01am Link  |  Print  |  Notify Moderator
Going by this chart:
Voltage Drop calc
Wayne Dohnal
Bend, OR.
Posted: 04/13/12 10:17am Link  |  Print  |  Notify Moderator
Here's a table that give resistance data for solid vs. stranded wire:
http://www.accesscomms.com.au/Reference/awgselection.htm
It shows, that depending on the exact stranding, the resistance of the stranded wire may be more or less than the same gauge solid wire, but is always very close. The biggest size on the table is unfortunately 14 gauge. I assume the same principle would hold for larger wires.
aruba5er
Neenah Wisconsin
Posted: 04/13/12 10:31am Link  |  Print  |  Notify Moderator
What randrx2 said. How are you going to measure the differance. But more importantly why do you want to? More surface area, lower resistance Skin effect, they say the current runs on the outside of the wire, not thru it. Concernd? get a bigger wire.
bigfootford
Fair Oaks, California
Posted: 04/13/12 10:55am Link  |  Print  |  Notify Moderator
Voltage Drop calc
Calulator is for wires in a bundle....not strands in a wire.
Jim
2000 2500 9.6 Bigfoot,94 F250, Vision 19.5, Mich 245/70XDS2's, Bilstein shocks, air bags/pump, EU2000, PD 9260,Lifeline 100ah, 200W. solar, Morningstar Sunsaver 15A/ display panel, Trimetric, Delorme/laptop, Holux gps rec,led lights, Wave-3 heat.
