RV.Net Open Roads Forum: Fifth-Wheels: Commode cleaning 101
 > Commode cleaning 101
Texas Two Steppers
Beaumont, TX
Posted: 04/13/12 05:27am Link  |  Print  |  Notify Moderator
I've been trying to figure out how to clean the 3" down pipe that extends about 15-18" below release mechanism before it dumps into the black water tank. I don't really want to stick my arm down there. What a crappy job.
2013 Duramax 3500 dually 4x4
2013 Excel Winslow 31RSE
TST tire monitor
Magnum MS 2012 inverter/charger
3-135w solar panels
Tristar controller
Trimetric monitor
4-6v Trojan t105 batteries
B & W companion 3000 hitch
Wills250psd
walnutcove NC
Posted: 04/13/12 05:35am Link  |  Print  |  Notify Moderator
small brush on a long pole
Dick_B
Palos Heights, IL USA
Posted: 04/13/12 06:20am Link  |  Print  |  Notify Moderator
Your question prompts me to try it since it hasn't been done in 8 seasons! I'm guessing a toilet brush could be used then immediately bagged and not carried thru the rig to the outside door.
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
phillyg
Front Royal, VA
Posted: 04/13/12 06:54am Link  |  Print  |  Notify Moderator
Your question makes me wonder if I should do the same. I'm not sure, but I believe you can find a chimney brush in a 3-4" size. They generally have a screw on fitting for a flexible wand. One wand should do it, then bag it like Dick stated.
2002 Keystone Cougar 286, 8,400lbs loaded, pulled with a 2004 F150 Supercrew, 5.4, 3.73 gears. Retired and enjoying life
Texas Two Steppers
Beaumont, TX
Posted: 04/13/12 06:57am Link  |  Print  |  Notify Moderator
Where would you find a chimney brush?
Ronald M
Traverse City, MI
Posted: 04/13/12 07:01am Link  |  Print  |  Notify Moderator
Sometimes toilet paper will hang up somewere down the line (usually at a fitting) I then use a 3" swim noodle and instert as needed to clear the obstruction. It's easy to use and not messy.
Ron & Agnes
1999 3865 Dutch Star DP
Updated 2009 Full paint, new carpet & tile
Spartan IFS Chassis 300hp Cummins
2010 Ford Escape
FMCA 333800
downtheroad
Pacific Northwest
Posted: 04/13/12 07:15am Link  |  Print  |  Notify Moderator
Get your wife to do it....
GMC Duramax LBZ
Komfort
Reese Dual Cam HP
Our Rig Picture...CLICK HERE
ferretgrandpa
Missouri
Posted: 04/13/12 10:48am Link  |  Print  |  Notify Moderator
DW uses a regular toilet brush for the pipe.
98 GMC 2500
RBW Lil Rocker 15K
08 Flagstaff 8526 RLS
TxTiger
North Texas
Posted: 04/13/12 11:22am Link  |  Print  |  Notify Moderator
I've used my camper twice and noticed the last trip there was some "stuff" stuck on the side of the pipe below the toilet. I used a bathroom cleaner in a spray bottle and put it on "stream" and it provided enough pressure to clean the sides. However, if this hadn't worked my next thought was to unhook the outside water hose and spray the pipe below the toilet flush.
2000 F250, 7.3 PSD, 6 speed manual, CC, SB
KZ 27TH Toy Hauler, 5,700 lb dry weight/8,000 lb GVW.
2010 Triumph Tiger 1050
2012 Triumph America
2009 Suzuki DRZ 400sm
tvman44
Southwest Louisiana
Posted: 04/13/12 11:24am Link  |  Print  |  Notify Moderator
I have never cleaned the pipe and cannot see the need for it except by people that have nothing else to do but worry about every little thing!
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
