RV.Net Open Roads Forum: Fifth-Wheels: sliding hitch questions
 > sliding hitch questions
chuggs
Posted: 04/15/12 02:01pm Link  |  Quote  |  Print  |  Notify Moderator
MC9 wrote:
If your front wheels come off the ground, reconsider.
That's what we like to call "self-critiquing"!!!
dubdub07
Colorado Springs
Posted: 04/15/12 03:09pm Link  |  Quote  |  Print  |  Notify Moderator
I gotta say....that's good stuff!
2012 Montana High Country 333DB
*NEW* 2012 Dodge 3500MEGA 6.7 CTD, 2012 Jeep JK Rubicon, 2012 Durango Citadel, 2010 Harley Heritage Softail....American STEEL = American profits.
jdog
Some Place
Posted: 04/16/12 06:56pm Link  |  Quote  |  Print  |  Notify Moderator
If your going to do that, why do you need a slider hitch? Just mount the fixed hitch further back. Would you do that?
Bunklash
Crestview, FL Panhandle
Posted: 05/28/12 01:23pm Link  |  Quote  |  Print  |  Notify Moderator
Hope I don't evoke any of the vitriol this topic seemed to bring out of some posters, but I have a question. I need to know if I can adjust my Reese slider hitch from "tow" to "manuever" position while hooked up. If so, just chock the wheels and ease it on up or back? Seems like it could be a little dicey.
Hope I get a quick response 'cause I need to go pick up ours pronto.
Thanks!
USAF retired, laid-off teacher
'08 Cameo 35SB3
'02 F350 PSD, CC, SRW, 2WD
One terrific wife, teacher too
Frost, the RooRoo dog
christopherglenn
a little over an hour from Yosemite
Posted: 05/28/12 01:50pm Link  |  Quote  |  Print  |  Notify Moderator
To slide the hitch while attached, unlock the slider, max out the brake controler then hold the brake controler on, and back up (or drive forward) a few inches. If the trailer brakes won't hold the trailer for sliding the hitch, chock the tires and have the brakes checked soon.
Only reason I wouldn't drive with the hitch slid back is it isn't designed for that. The mounting on my hitch puts the pin roughly between the four points, slide it back and you are on top of or behind the rear points. Static loading (sitting there) is far different from dynamic loading (hitting a pothole at speed).
2007 Chevrolet 3500 CC/LB Duramax/Dually 4X4 Mine r4tech, Reese Signature Series 18k +slider, duratrac, titan 62 gallon, diamond eye, Cheetah 64
2011 Keystone Fusion 405 TrailAir & Triglide, Centerpoint, gen-turi, 3 PVX-840T, XANTREX FREEDOM SW3012, G614
DaSu
St. Cloud Mn.
Posted: 05/28/12 05:04pm Link  |  Quote  |  Print  |  Notify Moderator
In my honest opinion , I would not take the chance of pulling while the hitch is in the slid back position . Maybe in a tight campgrounds, at low speeds , but quite honestly I would say your just looking for trouble and there is a good chance you will find it. It is my total understanding that the hitch was not made to pull in that position by the manufactures . Life is Good.
2005 F250 6.0 Power Stroke SRW Crew Cab
2006 33'Jayco Eagle
"Life is Good"
Bunklash
Posted: 05/28/12 07:44pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks christopherglenn. I'm gonna try your suggestion tomorrow morning. Coincidentally, I'd planned to inspect and adjust my brakes too.
Happy camping
