RV.Net Open Roads Forum: Fifth-Wheels: sliding hitch questions
 > sliding hitch questions
pjhansman
North Eastern Ontario, Canada
Posted: 04/14/12 05:17am Link  |  Quote  |  Print  |  Notify Moderator
Don't quite understand the problem. I have a 16k slider....takes maybe 30 seconds to get out of the truck and move it ahead or back. Why wouldn't you do it every time?
Phil & Rae.....and 2 feline furkids to make travel interesting
2011 Keystone Laredo 316RL
2005 Ford F250 SD, 6L PSD, 4x4
Yamaha EF3000iSE/B Inverter Generator
dubdub07
Colorado Springs
Posted: 04/14/12 09:09am Link  |  Quote  |  Print  |  Notify Moderator
The OP isn't questioning the process as I am sure he knows this. Circumstances are different for everyone. Why he wants to do this isn't our concern
2012 Montana High Country 333DB
*NEW* 2012 Dodge 3500MEGA 6.7 CTD, 2012 Jeep JK Rubicon, 2012 Durango Citadel, 2010 Harley Heritage Softail....American STEEL = American profits.
pjhansman
Posted: 04/14/12 10:10am Link  |  Quote  |  Print  |  Notify Moderator
The positions on the sliding hitch are clearly labeled "towing" and "maneuvering". Very clear in my opinion. My point was....if something takes only a few seconds than why would you consider doing it the wrong way?
It is also "relatively safe" at times not to wear your seatbelt, but I wear mine whenever I'm in a moving vehicle.
My apologies for not getting your approval prior to posting this reply.
RECVEH2005
Green Valley, AZ, USA
Posted: 04/14/12 10:23am Link  |  Quote  |  Print  |  Notify Moderator
I wouldn't compare towing a fiver with the hitch in a slid back position with towing a conventional travel trailer. Remember, a conventional travel trailer uses spring bars which transfer some of the tongue weight to the truck's front wheels and the trailer's wheels.
Mike
Mike & Donna Scheer
2013 GMC SRW Crew Cab 3500 short-bed D/A
2013 HitchHiker Discover America 300 FK
Mile High
Denver, CO
Posted: 04/14/12 10:43am Link  |  Quote  |  Print  |  Notify Moderator
Seriously, are you really that lucky that you always have the room to jump out and move it? Probably half the time I have to get through town first before I can find a safe place to put it back into tow.
2006 Ford F350 4X4 SB CC SRW Powerstroke 6.0
2013 Redwood 36RL - full paint - disk brakes
"Comparison is the thief of joy! - Theodore Roosevelt"
pjhansman
Posted: 04/14/12 11:10am Link  |  Quote  |  Print  |  Notify Moderator
Seriously, you're missing the point.
Yes, there've been times when I've had to pull for a distance with the slide in the maneuvering position. Because I HAD to.
There is a huge difference between advocating or condoning doing something wrong (and yes I consider it wrong) by choice, compared to doing it wrong because you have no alternative.
Just my opinion of course.
chuggs
Posted: 04/14/12 11:12am Link  |  Quote  |  Print  |  Notify Moderator
I don't see a problem with what he's doing... He's just running down a road a piece. Perhaps the slides on his hitch are older and don't work like new anymore.
As far as comparing to a bumper tow...you're right --- It's no comparison...
Let's assume a 2000 lb pin weight...4" aft of the axle... 2000x4=8000lb-in of force being applied to "lift the front tires"...
Now...Let's look at how many lbs of tongue weight on a TT would give the same ammount of force... On a short bed truck...the hitch ball is at least 35" aft of the axle... so 8000 lb-in / 35" = 228 lbs of tongue weight. I don't know anybody hauling a TT with a 228 lb tongue weight.
Regardless of what the OP does...he's still better off, in my mind, than towing a TT.
The only thing that he has to worry about really is how well the hitch rails can hold the weight in the maneuver position. I haven't looked at how much they reinforce the rails in the tow position v. the maneuver position. I can't imagine it's that big a deal to drive 10 miles down the road round trip.
Mile High
Denver, CO
Posted: 04/14/12 01:06pm Link  |  Quote  |  Print  |  Notify Moderator
Ah - OK. I re-read the OPs question and I see where you are coming from.
dubdub07
Colorado Springs
Posted: 04/15/12 01:23pm Link  |  Quote  |  Print  |  Notify Moderator
I still don't. It isn't unsafe nor illegal. The only reason I could see would be 1000 miles in the rear position might put 20% more wear on the truck.......
It is, however, illegal NOT to wear your seatbelt. Whether you choose to wear it or not.......
MC9
Cheboygan,MI
Posted: 04/15/12 01:35pm Link  |  Quote  |  Print  |  Notify Moderator
If your front wheels come off the ground, reconsider.
