RV.Net Open Roads Forum: Tow Vehicles: 20003 F250 V-10, spark plug change
Search only in Tow Vehicles
 > 20003 F250 V-10, spark plug change
MR MAC
BOSTON MA
Posted: 04/13/12 06:40am Link  |  Print  |  Notify Moderator
Dealer's quote under $500, motor has 143K, cylemder #4 has some misfire, changing coil had some improvement, but still there, thinking of doing my self but craling all over moter for a couple of days may not be worth the savings. service manager says plugs on the V-1o do not break off, its the longer pluges on smaller V-8's. Any advise.
ROBERT L MC INTYRE
nohurry
Orting, Wa
Posted: 04/13/12 07:21am Link  |  Print  |  Notify Moderator
Plugs on some of the V10 years can and do break off, but I think yours should be fine. Others with more knowledge may chime in, but for under 5 bills I would let them do it. I'm like you though, the older I get, the less I want to be working on vehicles myself. Good luck and let us know how it goes.
Carl
03 F-150, 5.4 Scab 4x4 auto 3:55
2011 Jayco 256RKS
Co-pilot-Sharon
Navigator-Missy (chihuahua)
NewsW
US
Posted: 04/13/12 07:28am Link  |  Print  |  Notify Moderator
If you are going to do the job (yourself or otherwise) put in the best premium plugs you can buy.
Capt Skup
Southern Maryland/Nantucket
Posted: 04/13/12 07:37am Link  |  Print  |  Notify Moderator
How long have the current plugs been in the engine? I think that is a big determining factor on how difficult that they are to remove. I think the night before while the engine is still warm, not hot, I would spray a blast of PB Blaster down around the spark plugs and let it soak over night. Also I would very gently break the plugs loose. Loosening a quarter turn at a time, gently using a loosening/tightening sequence to remove them. I would not just start spinning them out, for fear of breaking them off.
Capt Skup
AD-1(AW)USNRet.
Wonderful Wife,3 Daughters,2Goldens Gus&Riley
"Never get in a battle of wits with an unarmed man"
F-450 Lariat 4x4
Honda Odyssey EX-L
SunlineF281SR
SeaRay 240 Sundeck
http://community.webshots.com/user/CaptSkup?vhost=community
timc1207
Posted: 04/13/12 08:59am Link  |  Print  |  Notify Moderator
Here is some food for thought; I have a 2001 F250 with the V10 eengine, a couple years ago I changed the spark plugs myself and saved a lot of money; I thought.
About 500 miles later I blew a spark plug out of #1 cylinder, Fords service department said I did not torque the plugs correctly. The repair cost me $1300, $500 doesn't sound so expensive to me!
2008 Forest River Wildwood Le 27BHBS - 2010 Dodge 2500 Laramie Mega cab 6.7L Cummins diesel, Flo-Pro exhaust, XRT Pro tuner, Mygig Lock Pick, Access tonneau cover, Ranch Hand grill guard, KC daylighters.
fla-gypsy
North Florida
Posted: 04/13/12 09:16am Link  |  Print  |  Notify Moderator
Let them do it!
LIKE2BUILD
Mt. Zion, IL
Posted: 04/13/12 12:27pm Link  |  Print  |  Notify Moderator
joegray wrote:
I agree,,, let the dealer do it.
Personally, I have a hard time paying $500 for a job that only includes $50 in parts. But, if you're not comfortable with the task let someone else do it.
However, I would check with other independent shops. Dealer service rates can be pretty ridiculous!
KJ
'02 Jayco Qwest 324G
'04 Chevy 2500HD CrewCab |6.0L|2X4|4.10:1 | Eaton Posi-Trac
Curt MagnumV receiver
Eaz-Lift Hitch with Reese Dual Cam
2000 Crownline 205BR
'96 Polaris SLT780 PWC
'94 Polaris SLT750 PWC
3 Wonderful Sons (12, 6, & 4)
1 forgiving wife!!!
joegray
British Columbia, Canada
Posted: 04/13/12 09:39am Link  |  Print  |  Notify Moderator
n7bsn
Yes
Posted: 04/13/12 09:40am Link  |  Print  |  Notify Moderator
The early (1998 to mid 2000 or so) V10's had some issues with spark plugs snapping. Yours shouldn't
That being said, the fact you are asking implies you are not comfortable with the job
2008 F350SD V10 with an 2012 Arctic Fox 29-5E
When someone tells you to buy the same rig they own, listen, they might be right. When they tell you to buy a different rig then they own, really pay attention, they probably know something you don't.
45Ricochet
North Idaho
Posted: 04/13/12 10:05am Link  |  Print  |  Notify Moderator
fla-gypsy wrote:
Let them do it!
X2
06 Ram 3500 CC LB Laramie 4x4 Dually 5.9 Cummins Smarty Jr 48RE Jacobs brake
GVWR 12,200 RAWR 9350
06 Grand Junction 34' High profile 15500 GVWR 3200 pin Mor/ryde 5500 Onan genny Dual A/C Wet bolts
27' Hallett 502, 500HP
