RV.Net Open Roads Forum: Tech Issues: How to extend battery power
 > How to extend battery power
Page of 7
jyh818
Chino, CA
Posted: 04/13/12 08:06am Link  |  Print  |  Notify Moderator
First time dry camping at Silver Strand Beach. Beautiful place. No generators from 8 pm to 10 am! Battery lost juice at 2 am. Woken up by CO alarm beeping from time to time due to low voltage.
Solution, disconnect the ground on the battery just so we can sleep.
We're here for one more night. How can I extend the power? I can get another battery. What's a more permanent solution as we would come back here?
2002 Ford Excursion XLT 6.8L V-10 2WD, 4.30 Limited Slip
Rear Hellwig Sway Bar
2009 Skyline Nomad 260
Prodigy Brake Controller
EAZ-Lift WD Hitch
MEXICOWANDERER
las peƱas, michoacan, mexico
Posted: 04/13/12 08:16am Link  |  Print  |  Notify Moderator
Steel yourself jyh818 for 56 responses and opinions...
Your heater is probably sucking up a lot of fan power. WHILE BEING EXTREMELY WARY, try flipping on a stove burner on low flame and keep your bedroom window open a crack. You'll need to fully recharge that battery. Stay tuned for 56 additional responses...
CA Traveler
The Western States
Posted: 04/13/12 08:25am Link  |  Print  |  Notify Moderator
Don't use the furnace, add additional batteries, run the gen until 8pm and long enough to charge the batteries to 90%, solar to reduce gen run time, LED lights, understand battery power management, etc. Response 56.
2009 Holiday Rambler 42 Scepter with ISL 400 Cummins
2004 Honda CR-V
Bob
beemerphile1
I'm 57, I'm not a
Posted: 04/13/12 08:27am Link  |  Print  |  Notify Moderator
Was the battery fully charged to start with? What were you using? Even a single group 24 battery should last one night running a furnace unless the battery is bad.
I had a battery fail last fall. It was able to pass a 100 amp load test but a 1.5 amp load would kill it in 20 minutes.
Even if you are on the right track, you'll get run over if you just sit there.
- Will Rogers, American actor
CA Traveler
The Western States
Posted: 04/13/12 08:37am Link  |  Print  |  Notify Moderator
BTW Responses will be better if you post: battery type and number of them, charger type and model number, gen type and model. The other side is how much power you need/want to use.
3 tons
CA.
Posted: 04/13/12 08:52am Link  |  Print  |  Notify Moderator
This may already be obvious, but make sure your refer is not set to battery power.
3 tons
hershey
Albuquerque,(fulltime) NM, USA
Posted: 04/13/12 09:01am Link  |  Print  |  Notify Moderator
Use a lot of the above information but I really caution the option of using the stove burner for heat. Thats just a very dangerous practice.
hershey - albuquerque, nm
Someday Finally Got Here
Superman was an illegal alien.
NASCAR 14 - 99
jyh818
Chino, CA
Posted: 04/13/12 09:11am Link  |  Print  |  Notify Moderator
Wow. Lot's of responses. Thanks all.
More info:
Group 24 deep cycle. 690 MCA. No furnace used. Left bathroom light on. CPE 2000 inverter gen. Fully charged when we left the other campground with full hookups. Will try another battery.
Refrig set on gas.
powderman426
ohio
Posted: 04/13/12 09:39am Link  |  Print  |  Notify Moderator
If that's all youwere running, the battery is probably toast
Ron & Charlotte
WD8CBT since 1976
28' Prowler & 05 Ram QC LB
I started with nothing and I still have most of it left
I never fail, I just succeed in finding out what doesn't work
Crazy Ray
Monroe,La
Posted: 04/13/12 10:23am Link  |  Print  |  Notify Moderator
One group 24 ain't going to hack it. JMO. Get 2 6Volts GC from Sam's. JMO
RET ARMY 1980, DW Donna , "Tiny" (furkid) . Class A, 2007 Bounder 35E, Ford Chassis, 4 SAMS 6VOLTS,405W Solar,TriStar 45 Controller,1750W INVERTER, YAMAHA 2400, TOW: Honda CRV. READY BRAKE. "Living Our Dream". NASCAR FAN 14,18,20,11 LOVE CO & NM
Page of 7
