RV.Net Open Roads Forum: Class A Motorhomes: Didital Thermostats
 > Didital Thermostats
Sandy Korners
Marathon, FL
Posted: 04/13/12 08:09am Link  |  Print  |  Notify Moderator
I have a 2006 Holiday Rambler Ambasador. I would like to upgrade the thermostat. What is the overall opinion on the best digital thermostat to go with?
downtheroad
Pacific Northwest
Posted: 04/13/12 08:30am Link  |  Print  |  Notify Moderator
There are lots of them that are good and will work great...as long as they are battery powered..(not battery backup and hard wire powered).
The install was very easy and straight forward. I did add a spst switch from Radio Shack to control the fan speed.
Here is the one I used....Click
GMC Duramax LBZ
Komfort
Reese Dual Cam HP
Our Rig Picture...CLICK HERE
Sandy Korners
Marathon, FL
Posted: 04/13/12 05:44pm Link  |  Print  |  Notify Moderator
You are right on the money Diplomat Don. I am having a problem with the heat cycle. If I set the temperature at 72 it will not shut down when reached 72. The cycle does not work properly.
Diplomat Don
Moorpark, Ca
Posted: 04/13/12 12:17pm Link  |  Print  |  Notify Moderator
Sandy, you more than likely have two DuoTherm Heat Pump A/C units in your coach. You can't just change out the thermostat to any aftermarket unit. These two units talk with each other and the thermostat via data cables.
If yours is broken, you can contact PPL Motors they'll help you figure out what thermostat will work with your units. Before you call, you need to remove the interior vent covers and look at what model you have.
Lastly.....Is there a reason you need to change yours out, you didn't say what the issue is. If you just want something that is more sophisticated such as programmable on and off times, I don't think you'll find anything that will work with your units.
Don & Mary
2005 Monaco Diplomat 36SKT
400 Cummins
2012 Chevrolet Silverado LTZ CrewCab 4WD
2013 Polaris RZR 800 LE
judelaurenzo25g
Downey, CA
Posted: 04/13/12 08:41am Link  |  Print  |  Notify Moderator
I bought a $20 honeywell unit from Walmart in my toyhauler and it worked great. I'm about to do the same thing ti my MH
A ship in harbour is safe, but that is not what ships are built for.
bluwtr49
Green Valley, AZ
Posted: 04/13/12 10:31am Link  |  Print  |  Notify Moderator
Check this thread. Lots of good info.Thermostat
Dick
2000 40" DP Beaver Patriot Thunder Cat C-12 425 HP, 1550 Tq
1997 Jeep GC Limited ---toad
2008 Toyota Tundra Crew Max Limited TRD (Retired)
2009 Cougar 268 RLS ~8700 lbs road wt (Retrired)
2006 Jeep Liberty Turbo Diesel.....TV in Training
Diplomat Don
Moorpark, Ca
Posted: 04/14/12 05:08pm Link  |  Print  |  Notify Moderator
Sandy.....ours is also terrible.....alot has to do with the location of the sensor for the A/C and heating. On my coach, there is a small white cage under the front TV that has the sensor in it. Again, I'm guessing that yours is in the same spot, with one more in the rear bedroom. The front one reads the heater temp. It was a TERRIBLE place to put it because of the heat and cold that comes off of the windshield. I removed mine from that location and had enough wire to pull it through the cabinet above the passenger seat and then drilled a hole through the cabinet and dropped it down by the manual sunshade.
There is also a rest procedure for the thermostat if you think that it is malfunctioning. If you're interested in the procedure, send me a PM with your email and I'll send it to you.
dougrainer
Carrolton, Texas
Posted: 04/14/12 05:19pm Link  |  Print  |  Notify Moderator
The reset procedure DOES nothing for operational issues. All it does is verify the DIP switch settings on each control board. Nothing else. Doug
edatlanta
Panama City Beach, FL
Posted: 04/14/12 06:13am Link  |  Print  |  Notify Moderator
While I know many here have been successful in using after market battery powered thermostats, I am a firm believer in using the a/c manufacturers digital model. They are designed to work with the a/c's that I have and they are are designed to run on 12v. Yes they are more expensive, but the warranty on my two a/c's doesn't come into question either.
Ed
2006 GMC 2500HD CCSB 4x4 Duramax/Allison, Titan 52 gallon fuel tank, TTT/Schefenacker Towing Mirrors, Prodigy Controller, B&W Companion Hitch, Progressive Industries EMS-PT50C, TST Systems 507 TPMS
2010 Jayco Designer 35RLTS,Cummins/Onan RV QG 5500 EVAP
dougrainer
Carrolton, Texas
Posted: 04/14/12 06:47am Link  |  Print  |  Notify Moderator
That is NOT the tstat's fault. It is the PLACEMENT of the Tstat. Your CCC tstat system has 2 ways to sense the temp depending on what Monaco did on your unit. The wall tstat is the default ZONE 1 temp sensor. IF the wall Tstat is NOT installed on a interior wall but in an overhead cabinet or in a back hall way, then they use a remote Temp Thermister. This remote thermister will look like the one in the bedroom, either brown or white about 1 inch around with slots in it. Some Monaco front Zone 1 Thermisters were installed too close to the front dash area or by the front TV mount and that caused a higher than normal temp sense and under warranty back then they paid to relocate. So, If you do NOT have the remote front sensor, you can add one if the Tstat IS the sensor and is not in a good location to correctly sense the temp in the RV. But as others have pointed out, there is NO WAY to add any other tstat without spending hundreds of dollars on new ac control boards and then running the required tstat wiring from the AC units to the wall area. You CAN install a seperate digital tstat just for the furnace very easily on this type system. Doug
