jwboudreau
Westminster, MA USA
Does anybody blow their water lines out in the spring, getting the anti-freeze out and then running water through to clean the lines. We are going out next week and just debating whether I want to drain the lines first by blowing them out, or wait and just run water through when we get to our location.
donn0128
Pronounced Ore-gun
Blowing them out will not sanitize them. You really need to properly sanitize the system before yse.
Donn,Lorri,Max (The Rescued Lab)
Resident Know It All
christopherglenn
a little over an hour from Yosemite
If you want to save / recycle what is in the lines, blow them out. No matter what flush them, then sanitize, then flush again. Antifreze is not antifungal.
2007 Chevrolet 3500 CC/LB Duramax/Dually 4X4 Mine r4tech, Reese Signature Series 18k +slider, duratrac, titan 62 gallon, diamond eye, Cheetah 64
2011 Keystone Fusion 405 TrailAir & Triglide, Centerpoint, gen-turi, 3 PVX-840T, XANTREX FREEDOM SW3012, G614
powderman426
ohio
I usually pressurize the system then go to each faucet and run into a jug till I see the color changing. I am able to save probably 3/4 of what I put in. No I'm not cheap, just frugal.
Ron & Charlotte
WD8CBT since 1976
28' Prowler & 05 Ram QC LB
I started with nothing and I still have most of it left
I never fail, I just succeed in finding out what doesn't work
M GO BLUE
Southgate, MI
Hook up to city water, flush the lines...done!
...and before everyone starts typing back no we don't use our lines to drink or cook with
2005 Chevy Silverado 3500 dually CC/LB Duramax/Allison
2008 Jayco Designer 35RLTS fifth wheel
Onan 5500W Marquis Gold gas generator (HGJAB - 1038D)
MICHIGAN RALLY - July 19-21, 2013 Click here
omatty
nashville, tn
whats the best way to sanitize?
filthy beast
New Mexico
I blow my lines out every fall. In the spring, I fill the water tank and add 1/4 cup of bleach per 15 gallons of water. I then pump that through the system, including the water heater. Let that sit for a few hours while I do other stuff and then drain down the fresh water tank and water heater. Fill with fresh water and start pumping that through the lines until I can smell no more chlorine. Top off the tanks and I'm good to go. We don't usually drink the water from tanks either.
Goody Two Shoes and the Filthy Beast
2008 Silverado 2500HD
2012 Wildcat 282RKX
1 Damnatian!
You cannot make things idiot proof, you can only make them idiot resistant.
RoyB
King George, VA
We dont drink or cook from the tanks either... Just for baths and washing dishes.... Who knows where that water has been haha...
Roy and Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
POPUP PHOTOs-Pg52-Pg56
dannytas
Pioneer, CA
I blow out my lines when I winterize the 5er. Drain the hot water tank and flip the by-pass valves. I keep all the faucet open, as well as the drains, all of them! The only place I use "antifreeze" is in the drains with "p" traps.
When I'm ready to take the 5er out I fill the fresh tank with water and a 1/4 cup bleach. Then I run it through the system, leaving it in the gray tank for a while. The next day I flush with fresh water. Done.
1994 Coleman Destiny Cedar XL
1989 Fleetwood Terry Lite
DW-Lynn
BigDog-Kelley
LittleDog-Kroozer
skipnchar
Topeka or somewhere else
Blowing them out is OK but unnecessary. flushing water through your lines after simply opening the low point drains and faucets for a while, will have the same effect. You should sanitize the entire system anyway and that should also remove any residual antifreeze taste.
