I discovered that a "miracle" I've heard of for quite some time actually is true!!!
We got back from a three week trip down to the gulf coast (Pensacola) a few days ago. The front of our Spree was plastered with bugs and bug stains. I washed it. The really gross, outrageous bug bodies were removed, but left behind a mottled mess of bug stains. I tried Turtle Wax Bug & Tar remover, to little effect. I tried "Goof-Off", to little effect. Hmmmmmmmmmmmm . . . . . As a last resort, I thought I'd try that old wive's tale that some people swaer by . . . . Bounce dryer sheets. Why the heck not, I had nothing to lose.
I got the area wet first, then gently rubbed and buffed with a wet Bounce sheet. The stains were all removed, or at least greatly reduced! After the rubbing and buffing, I wiped and hosed off the Bounce residue, and used a chamois to dry.
I'm tellin' ya, you gotta try it if you haven't already!
Walter & Garland - Camp Canine caretakers
Gen. Gretchen - 9 y.o. GSD - Special Forces/Seal/DOTL Cloudbusters
Gen. Missy - GSD/Aussie - Joined Special Forces/DOTL Rainbow Division, June 11,2006
Miss Inga - 9 week old GSD. Still a civilian at this point.
DOTLDaddy wrote: I discovered that a "miracle" I've heard of for quite some time actually is true!!!
IMO, not a miracle at all rather a chemically treated piece of material that has more than one use.
A miracle would be if you rubbed the entire vehicle and it turned into a brand new 2013 KZ Spree!
The best product that I have found is BugOff; it comes is a spray bottle. It does an outstanding job of removing bugs form the windshield and the front of the vehicle. Not sure, but it may remove any wax that has been applied to the vehicle. I clean off the bugs and then just reapply wax to the front. Works for me.
