RV.Net Open Roads Forum: Help me find a chair base hold-down, please
 > Help me find a chair base hold-down, please
Noel
Southern Oregon
Posted: 04/13/12 10:59am Link  |  Print  |  Notify Moderator
We have a heavy rocker-recliner behind the passenger seat. It is not bolted to the floor. It has a swivel hoop base which is round 3/4 or one inch steel tubing.
I went to www.glastop.com and saw a dandy chair clamp. Alas, they are out of stock and have no hopes of finding another supplier.
Can anyone direct me to a chair clamp, hopefully, with a release, so it can be moved. I will settle for a permanent clamp.
Guess I could buy a couple of heavy duty steel U-bolts and drill down into a compartment below and use a steel plate to secure the chair with lock washers and nuts.
Any help would be appreciated.
Noel
2003 National Dolphin LX 6335, W22, 8.1L
Crazy Ray
Monroe,La
Posted: 04/13/12 11:02am Link  |  Print  |  Notify Moderator
try PPL in Houston Tx
RET ARMY 1980, DW Donna , "Tiny" (furkid) . Class A, 2007 Bounder 35E, Ford Chassis, 4 SAMS 6VOLTS,405W Solar,TriStar 45 Controller,1750W INVERTER, YAMAHA 2400, TOW: Honda CRV. READY BRAKE. "Living Our Dream". NASCAR FAN 14,18,20,11 LOVE CO & NM
rvten
Crossville,TN
Posted: 04/13/12 11:03am Link  |  Print  |  Notify Moderator
Winny had one for our 2001 Adventurer. I never used it.
Should be something you can get from a dealer or from Winny.
Tom & Bonnie
Crossville, TN.
Aspect 29H 2008 Type C
Ford Flex SEL 2010
There is no B+
Kiwi_too
Western, WA
Posted: 04/13/12 11:11am Link  |  Print  |  Notify Moderator
We have a similar setup. Behind the passenger seat we replaced the barrel chair with a recliner. Behind that is the entry steps. I took a screw out of the metal molding, near the wall and put on an eye hook screw. We use a bungee around the legs to the eye hook.
May God bless your travels
Me, The Wonderful Wife
and two Spastic Border Collies
U.S. Army Retired
2004 Coachmen Aurora, 3480DS
2007 Saturn Outlook, FROG
Clay L
Sioux Falls, South Dakota
Posted: 04/13/12 11:47am Link  |  Print  |  Notify Moderator
Winnebago provides a clamp with a knob that you turn to tighten it down. On mine the knob has a long bolt that goes through the floor and into the storage compartment below with a nut and washer on it.
You can probably get the part from Winnebago through Lichtsinn Motors LICHTSINN. They are a dealer a mile or so from the factory.
If you call Lichtsinn have your VIN handy. They can cross it to your ID number so they will know which parts are on your coach.the clamp can be obtained from Lichtsinn Motors.
Clay (WA5NMR), Lee (Wife), Katie (cat).
Full Timing in a 2004 Winnebago Sightseer 35N, Workhorse chassis, Honda Accord toad
ArchHoagland
Clovis, CA, USA
Posted: 04/13/12 01:28pm Link  |  Print  |  Notify Moderator
Go to Lowes, Home Depot, etc and check out the metal pipe section.
1" or 3/4" pipe clamps would work fine depending on the base ring size.
Use lag bolts or go through the floor if possible to anchor the chair.
You can paint the pipe clamps to match.
2004 Monaco La Palma 36DBD
Workhorse W22 8.1 Gas Allison 1000, 7.1 mpg
US Gear Brakes
Nothing is either good or bad, but thinking makes it so.
Peg Leg
Anderson, IN
Posted: 04/13/12 02:24pm Link  |  Print  |  Notify Moderator
For a modification to the pipe clamp idea. They should have a bolt stud with lag screw threads on one end and regular 1/4-20 on the other. You can anchor the lag end into the floor and place a pipe hangar on it then a large plastic handled wing nut to hold it in place.
2012 Chevy 3500HD Dually 4X4
Crew Cab long bed 6.0 gasser 4.10
06 Hitchiker II LS 29.5 FKTS
Yamaha EF3000iSE
retired gadgetman
rvten
Crossville,TN
Posted: 04/13/12 02:25pm Link  |  Print  |  Notify Moderator
Just check underfloor before drilling.
rgatijnet1
Posted: 04/13/12 02:54pm Link  |  Print  |  Notify Moderator
Metal conduit clamps at HD or Lowes and lag bolts.
hershey
Albuquerque,(fulltime) NM, USA
Posted: 04/13/12 06:54pm Link  |  Print  |  Notify Moderator
I'd suggest using a couple blind nuts mounted below the floor in the basement compartment. Then a couple 3/8" wing bolts long enough to go through the base ring of the chair, the floor and into the blind nuts. Simply insert the pair of bolts and tighten securely before moving down the road.
hershey - albuquerque, nm
Someday Finally Got Here
Superman was an illegal alien.
NASCAR 14 - 99
